Re: Axle swap 7.25 small bolt to big bolt
[Re: my74dart]
#1610183
04/21/14 11:26 AM
04/21/14 11:26 AM
RapidRobert
Thoughts?
iirc there is a difference (bearings/housing inner dia) somewhere inside that precludes you from swapping SBP axles into a BBP housing & vice versa. Swap the whole rear end. There are sure grips available (clutch and cone) but they are pretty scarce but they sure function nice in snow on a DD A body and Randy's has improved spider gears which is the weak(est) point on them (you did say you are going thru it) but as you know they cant take a whole lot of hot rodding. EDIT Split the u bolt nuts with a nut cracker (Sears has one that works good) and rethread the shank below the nuts with a "thread chasing" not a regular die then easily take off the nuts. You might have to undo the nuts slightly so you can get at em with the cracker. Trust me on this one.
[Re: 65rbdodge]
#1610185
04/21/14 02:35 PM
04/21/14 02:35 PM
Posts: 20,179 Park Forest, IL
slantzilla
Park Forest, IL
Wheel bearing, retainer, and spacing from the bearing to the flange are all different.
