Re: Can anyone help me identify an old big block cam
[Re: dogdays]
#1610122
04/21/14 01:06 AM
04/21/14 01:06 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Doesn't matter. NO cam from the '70s or '80s is as good as a modern grind, if you are looking for max power.
R.
Unless its a MP 509 or MP 590.
[Re: moparjoe360.4]
#1610123
04/21/14 12:11 PM
04/21/14 12:11 PM
Posts: 2,489 Pacifica, CA
Devilbrad
Pacifica, CA
My dad removed a cam from his 383 this weekend thinking it was an old Crane but it's not. The cam came out of a 426 wedge in the late 70s or early 80s and he was told it was a"lumpy Crane" the only markings on it are RPD 21, and J 20 50. Ive tried googling the # with no luck. Any help would be great.
If you are close to Dayton, give Kammer & Kammer a call. They have a cam profiling machine and don't charge very much to run the cam in it to get you the full specs.
