9.25 vs 8.75 #1609801
04/20/14 03:24 AM
04/20/14 03:24 AM
Iowa
76dodgeboy Offline OP
Iowa
So what would you rather have under your ride? There's a guy looking for some 8.75 gears on the web and some kid is telling him to use the "Mini Dana" 9.25 claiming its stronger. From that I've heard the 9.25 is kind of a turd when abused too much. The guy wanting a center section has a twin turbo setup currently running 13s but he said he's upgrading turbos to run 10s. The kid that says the 9.25 is a mini Dana said a guy buy him blew his 8.75 a few times than installed a 9.25 with no issues and was in a 600hp D100. So who's been in momies meds ?
Re: 9.25 vs 8.75 [Re: 76dodgeboy] #1609802
04/20/14 03:46 AM
04/20/14 03:46 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
If that's the one that is in my 03 Dakota, no thanks I'll take the 8 3/4
Re: 9.25 vs 8.75 [Re: ademon] #1609803
04/20/14 03:58 AM
04/20/14 03:58 AM
Iowa
Iowa
12 bolt cover shaped like a stop sign
Re: 9.25 vs 8.75 [Re: ademon] #1609804
04/20/14 07:32 AM
04/20/14 07:32 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Most Dakota's are 8.25" some were built with 9.25"
9.25" is a good unit, I have had no problems with an 8.75" even beating on one with a 440 stick for years.
Usually the factory suregrips are the issue with the 8.25 and 8.25, junky designs.
"I think its got a hemi"
Re: 9.25 vs 8.75 [Re: 76dodgeboy] #1609805
04/20/14 10:04 AM
04/20/14 10:04 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
I consider them nearly equal stock. There is more aftermarket stuff for the 8 3/4. If you're running 10's it will be ALL aftermarket internals.
Re: 9.25 vs 8.75 [Re: redraptor] #1609806
04/20/14 10:14 AM
04/20/14 10:14 AM
AZ
Mike P Online content
Mike P  Online Content
AZ
I've run several of both in various projects (currenly have a 9 1/4 in the 57 Plymouth with a 1st Gen Hemi and 4 speed).
I personally like the drop out center section of the 8 3/4 but I can find the 9 1/4s for about 1/2 the price of the 8 3/4s.
As far as strength and reliability my experience is that is about a wash.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
Re: 9.25 vs 8.75 [Re: 76dodgeboy] #1609807
04/20/14 10:29 AM
04/20/14 10:29 AM
Locomotion Offline
Locomotion  Offline
Doesn't the 9 1/4" have C-clip axle retainers? I don't know what's available, like 10 & 12 bolt GM rears have, but I figure it's not worth the trouble. 8 3/4" would be safer, along with the previously mentioned parts availability and drop-out convenience.
Could do a rear Dana 60 right and just about forget about having any issues!
Re: 9.25 vs 8.75 [Re: Mike P] #1609808
04/20/14 10:32 AM
04/20/14 10:32 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Actually, shame on this guy.
IF he can afford a car like that and run those numbers, he SHOULD have already known the answer and the discussion closed.
Re: 9.25 vs 8.75 [Re: Commando1] #1609809
04/20/14 01:26 PM
04/20/14 01:26 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Lots of 4,000 lb Dakotas with stock 9.25s in them running 11s. And even a handful into the 10s
Seems strong enough to me.
**Photobucket sucks**
Re: 9.25 vs 8.75 [Re: Commando1] #1609810
04/20/14 01:51 PM
04/20/14 01:51 PM
Iowa
Iowa
He's wanting 8.75 stuff Not 9.25. the kid is the one saying through 9.25 is better.
I mentioned converting a truck D60 over to 5lug and told him to contact DoctorDiff
Re: 9.25 vs 8.75 [Re: 76dodgeboy] #1609811
04/27/14 01:41 PM
04/27/14 01:41 PM
Earth
Rob C Offline
Rob C  Offline
Earth
It is a C-clip rear, If you all ready have the 9-1/4, then it is worth an upgrade to better axles. But I would not purchase one to go fast.
I don't know if there are any C-clip eliminator kits for that rear.
Re: 9.25 vs 8.75 [Re: 76dodgeboy] #1609812
04/27/14 01:59 PM
04/27/14 01:59 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Ummm....am I the only one here that thinks he has more issues than just the rear end???
Re: 9.25 vs 8.75 [Re: Dcuda69] #1609813
04/27/14 02:23 PM
04/27/14 02:23 PM
Kirkland, Washington
Pacnorthcuda Offline
Maybe it's a twin turbo slant 6 in a C body?
Re: 9.25 vs 8.75 [Re: Pacnorthcuda] #1609814
04/27/14 03:50 PM
04/27/14 03:50 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
the 9.25 was made to be as strong as the dana 60---putting a c-clip on it was the major mistake---if you want to race one you can do a c-clip elimination with either 8.75 axle ends or a 9" axle end--then have axle shafts made to fit...
Re: 9.25 vs 8.75 [Re: 70Cuda383] #1609815
04/27/14 05:17 PM
04/27/14 05:17 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The issue with C clip rearends was made famous by GENERIC Motors. The Mopar 8 1/4" and 9 1/4" axles do not have the same type of failures.
Re: 9.25 vs 8.75 [Re: Kern Dog] #1609816
04/27/14 05:20 PM
04/27/14 05:20 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
must be on some outlaw tracks....
Re: 9.25 vs 8.75 [Re: Kern Dog] #1609817
04/27/14 05:35 PM
04/27/14 05:35 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The only downside to the 9-1/4 is the cost of aftermarket parts - but then if you drive a Mopar you're already used to that! FWIW, the 9-1/4 is a true "Mopar" item - unlike the dana. The strength comes from the ring gear size so the 9-1/4 should be stronger than anything but a dana - given the same quality of gear in each. It is apparently easier to work on than a dana.
If you were going to buy a rear end and then shorten it, swap gears and diff, etc, etc, then there's no excuse not to go with a 9-1/4 versus an 8-3/4.
Re: 9.25 vs 8.75 [Re: Stanton] #1609818
04/27/14 05:45 PM
04/27/14 05:45 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
For an axle that one intends to keep a specific set of gears in, the 9.25 is great. The appeal of easy gear swaps without consulting a gear shop is a major factor in choosing the 8 3/4" axle.
Re: 9.25 vs 8.75 [Re: Kern Dog] #1609819
04/27/14 07:02 PM
04/27/14 07:02 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Chrysler must have put some invisible safety strap that holds a broken axle in in the 8.25 & 9.25 & mine failed when I broke it mud riding an 80' model I had once
That tire/wheel,axle stub & brake drum came out of there just a fast as my old 66 GTO axle did when introduced to slicks & 550 ft lbs of torque & a 4800 rpm clutch dump
I don't see the difference
Re: 9.25 vs 8.75 [Re: BulletBob] #1609820
04/27/14 10:23 PM
04/27/14 10:23 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You could take an axle out of a Kenworth big rig and stuff it under your car and in the right circumstances break it! That doesn't mean its a weak rear end !!!
My feeling is that a 9-1/4 would not break under the same circumstances as that POS GM unit. However, the GM unit would not have lasted as long as the 9-1/4 in the mud.
If you're going to compare things, do it on equal terms !!!
