Page 7 of 7 1 2 3 4 5 6 7
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609726
05/03/14 12:36 PM
05/03/14 12:36 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Carb retention bolts were "RSC" bolts and not an "H" head bolt as often promoted by "OE Correct" bolt sellers.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609727
05/03/14 12:38 PM
05/03/14 12:38 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
In case you get into an argument about what color your fan clutch seal should be, this example was red, I've also seen black ones but I couldn't verify what year they came off of.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609728
05/05/14 03:25 AM
05/05/14 03:25 AM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
Hey Scott, I was reading through this post again and saw you wanted a picture of the power steering pump on my old duster. This car didn't have any performance axle package, just a 3.23 peg leg car. Hard to see, but it is a solid pulley on it.. It was a relatively original car with very few things replaced over the years, water pump being one of the few things. still retained the original heater hoses, spark plug wires, and even plugs..
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609729
05/05/14 12:03 PM
05/05/14 12:03 PM
New York
Mopucky Offline OP
Mopucky  Offline OP
New York
Very good info Scott Thanks for posting! I've referenced this many times now.
Re: 1971 340 Cuda Engine Paint Details [Re: Mopucky] #1609730
05/16/14 08:55 AM
05/16/14 08:55 AM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
Scott,
I thought I had read that the power steering pump cap was painted black originally. The poor paint job didn't stick very well and usually flaked off like the dipstick. I can't tell in your post if yours is painted black.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: 1971 340 Cuda Engine Paint Details [Re: FJR doc] #1609731
05/16/14 09:20 AM
05/16/14 09:20 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes it's painted black, can, cap, cast iron body, cooler, and brackets, all black.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609732
05/16/14 12:37 PM
05/16/14 12:37 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Scott
Is the fan stenciled or stamped..
I know what it should be, but I've seen it both ways on two different what were presented as, original 71 A-body 340's.
Re: 1971 340 Cuda Engine Paint Details [Re: mccannix] #1609733
05/16/14 12:54 PM
05/16/14 12:54 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Ive only seen ink stamped on original 71's, however most Ive seen were early engines from the Windsor plant, that might have changed after the move to Mound Road.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609734
05/30/14 02:24 AM
05/30/14 02:24 AM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
I was following this post because I knew I'd be pulling the water pump on my 71 Challenger 340 which I've owned since June 1972. I pulled the water pump yesterday and have looked at the bolts Scott has shown and mine has the same bolts. I changed the water pump in May 1974 but reused all the parts except the pump. My car has a build date of Dec 1970 at Hamtramck plant. Here's what I found. My fan clutch has a part number of 3462112 painted on it and has a blue seal. There's a white paint stamp on the fan which says "engine side". The bolts for the water pump also have nylon inserts drilled into the threads to lock the bolt in except for the top center bolt. That's what I've been able to check so far.
Terry
Re: 1971 340 Cuda Engine Paint Details [Re: 71vert340] #1609735
06/01/14 07:00 PM
06/01/14 07:00 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
I'll see if I can add pictures to my post above. Let's see if it works.
Re: 1971 340 Cuda Engine Paint Details [Re: 71vert340] #1609736
06/01/14 07:01 PM
06/01/14 07:01 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
And another pic to above.
Re: 1971 340 Cuda Engine Paint Details [Re: 71vert340] #1609737
06/01/14 09:03 PM
06/01/14 09:03 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
Since we're looking at small block details, I'll enclose a pic of the water pump I just pulled off. It was installed in 1974. The number on it is 2951571-3-05102. It has the pentastar on it but is different than the rebuilt one. Is it a genuine Mopar part or an aftermarket produced part? I can't remember where I bought it in Tacoma Wa. I asked this on another Mopar site but got no response. Thanks.
Terry
Re: 1971 340 Cuda Engine Paint Details [Re: 71vert340] #1609738
06/01/14 09:16 PM
06/01/14 09:16 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Water pump looks to be authentic Mopar, but a later replacement casting number. The fan looks the same as the few I have. Can you make out the digits on the center of the fan clutch (date code - G17A ?).
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609739
06/01/14 09:27 PM
06/01/14 09:27 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
It's either G17A or 617A. Looks closer to a G but hard to tell. It's going back together tomorrow as I want to get it in the TriCities Mopar show next weekend in Richland. I'm glad I took pictures of this while apart. I almost cleaned and painted the Fan/clutch assembly but decided to leave it as is so as not to lose the original stamps. Thanks.
Terry.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609740
06/01/14 09:29 PM
06/01/14 09:29 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
The freshly painted fan on the right is a six vane pump. I was going to install it but when I pulled the pump I installed in 1974, it's an 8 vane. I'll probably send it out to be restored by the company that did the one on the right.
Re: 1971 340 Cuda Engine Paint Details [Re: 71vert340] #1609741
06/06/14 09:03 AM
06/06/14 09:03 AM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
Scott
Do you have any pictures of your detailed power steering box? I will be sending mine out to Firm Feel for rebuilding and will need to detail it once I get it back.
Kevin
Kevin
