Page 6 of 7 1 2 3 4 5 6 7
Re: 1971 340 Cuda Engine Paint Details [Re: 5carguy] #1609706
05/03/14 10:16 AM
05/03/14 10:16 AM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
Scott. The driver side exhaust manifold used the heat shield/ gasket. Am I correct that the factory didn't use a gasket on the passenger side exhaust manifold.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: 1971 340 Cuda Engine Paint Details [Re: FJR doc] #1609707
05/03/14 10:17 AM
05/03/14 10:17 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
FJR, that is correct
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609708
05/03/14 10:22 AM
05/03/14 10:22 AM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
Wow that was fast!! Did you do anything to your exhaust manifolds other than cleaning them up and painting them with engine paint?
Kevin
Re: 1971 340 Cuda Engine Paint Details [Re: FJR doc] #1609709
05/03/14 10:23 AM
05/03/14 10:23 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
This set has been extrude honed for more flow but otherwise no.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609710
05/03/14 11:12 AM
05/03/14 11:12 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The following details overlap with some of the items I already posted on other threads but you might find them helpful. Keep in mind that this is a 1971 engine assembled at the Windsor Ontario plant in September of 1970. These details varied with year, time of year, and plant throughout 340 production. This is a very original "survivor engine" only a very short list of items have ever been changed on it.
Here is one of the exhaust manifold bolt head markings, there were a couple different ones used on this engine
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609711
05/03/14 11:14 AM
05/03/14 11:14 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here is another one. This is the "Dog Bone Bolt" same bolt used for 1970-71 Hemi Carburetor hold down bolts only rather than being black phosphate as on my example, the carb bolts were clear zinc plated. This engine didn't have any of the commonly called "correct" "H" head marking bolts.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609712
05/03/14 11:15 AM
05/03/14 11:15 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Another look
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609713
05/03/14 11:17 AM
05/03/14 11:17 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The 3rd style exhaust manifold bolt
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609714
05/03/14 11:20 AM
05/03/14 11:20 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The Engine mount bolts had "RBW" on the heads
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609715
05/03/14 11:21 AM
05/03/14 11:21 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Intake Bolts have an "E" on most of them
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609716
05/03/14 11:23 AM
05/03/14 11:23 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Lots of good clues on this original throttle bracket
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609717
05/03/14 11:26 AM
05/03/14 11:26 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
There are still some questions about distributors being installed before or after paint. The clues this engine provides helped me decide which way to go on my engine. The small amount of paint all the way down to the inner lip of the seal area leads me to believe the distributor was not installed but rather, a plug was inserted into the open hole to keep paint out of the engine. Had the distributor been in place the steel base flange would have likely covered and protected this area.
*Notice how the previous owner added the "dandelion seed" oil additive
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609718
05/03/14 12:22 PM
05/03/14 12:22 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Power Steering Bracket bolts were just plain with 3 hash marks (grade 5)
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609719
05/03/14 12:23 PM
05/03/14 12:23 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Alternator bolts were a mix, this "F" bolt was used as a water pump bolt when the engine was painted and reused when the alternator was added.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609720
05/03/14 12:25 PM
05/03/14 12:25 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
This is the "Long" upper alternator bolt
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609721
05/03/14 12:26 PM
05/03/14 12:26 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Alternator, lower bolt is also an "F" bolt
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609722
05/03/14 12:29 PM
05/03/14 12:29 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Negative battery cable was added after paint, bolt has an "E" head marking and was plated a light gold/zinc. That yellow paint you see is the original machining/assembly markings showing through the original thin orange paint.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609723
05/03/14 12:31 PM
05/03/14 12:31 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Valve cover bolts all has an "E" head marking
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609724
05/03/14 12:32 PM
05/03/14 12:32 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Crank pulley details
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609725
05/03/14 12:34 PM
05/03/14 12:34 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Power steering bracket bolt head "A" served double duty as a lower water pump attaching pulley and was painted with the engine before the bracket was added.
