Page 2 of 7 1 2 3 4 5 6 7
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609626
04/19/14 09:34 PM
04/19/14 09:34 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609627
04/19/14 09:35 PM
04/19/14 09:35 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609628
04/19/14 09:36 PM
04/19/14 09:36 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
N
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609629
04/19/14 09:36 PM
04/19/14 09:36 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Original choke well gaskets were thick and made of an asbestos composite (this one is NOS).
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609630
04/19/14 09:37 PM
04/19/14 09:37 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Rear Coil bracket mounting bolt head marking had an "E" and was plated a yellow/zinc color.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609631
04/19/14 09:37 PM
04/19/14 09:37 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Ok, you should have an orange engine assembled at the Windsor Ontario plant. Here are a few that might get you on your way. This shows all of the parts which were attached before the engines were painted.
Is that actually an 71 A-body motor? Would an E-body just have a different drivers exhaust manifold? Everything else the same.
Spring Fling 37 May 3 & 4, 2025 at Woodley Park, Van Nuys CA
600+ Mopars, 200+ swap, midway, Friday Malibu cruise,
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609632
04/19/14 09:38 PM
04/19/14 09:38 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, correct, that and the engine mount is a different shape for E-body
The front coil mount strap bolt had an "F" shaped head marking and was black/grey phosphate.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609633
04/19/14 09:38 PM
04/19/14 09:38 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
This is a reproduction coil made by M&H Wire. They are the closest match to my originals in terms of the ink stampings. Aside from the stampings, all modern replacement coils (like this one) lack some details as compared to originals which have either "Made in USA" or "Made in Canada" molded into the ends (my car should have had "Made in Canada") reproductions don't have either. Originals are also about .25" shorter than reproductions.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609634
04/19/14 09:39 PM
04/19/14 09:39 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Notice that the coil wire has a white ink printing as opposed to yellow? I have only seen this on originals, all reproductions are yellow.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609635
04/19/14 09:39 PM
04/19/14 09:39 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Distributor clamps were steel with a very thin copper plating which was burnished with a very thin/low quality dark coating that appears like black phosphate, copper color shows through in several areas.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609636
04/19/14 09:40 PM
04/19/14 09:40 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Correct NOS distributor cap, all originals should have "Made in USA" molded in.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609637
04/19/14 09:41 PM
04/19/14 09:41 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
V
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609638
04/19/14 09:41 PM
04/19/14 09:41 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
W
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609639
04/19/14 09:42 PM
04/19/14 09:42 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
All original vacuum hoses were ribbed like this one, this one is NOS.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609640
04/19/14 09:43 PM
04/19/14 09:43 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
All original Keystone clamps I've seen were stamped with this 615 number. This is a reproduction, it differs from an original in that the 615 is stamped upside down as compared to an original.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609641
04/19/14 09:43 PM
04/19/14 09:43 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
This is an NOS and date correct early 1971 Fuel filter. The ink stamping is a lighter shade of blue as compared to reproductions. These were supplied to the line as assemblies with clamps and pre cut fuel lines as shown. I used reproductions on my engine and stashed this one for reference purposes.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609642
04/19/14 09:44 PM
04/19/14 09:44 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here is the reproduction fuel filter. Notice how much brighter and bold the KV stamping is? Close but no cigar, font and pattern is decent but it's too bright, and very obvious when compared to an NOS original.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609643
04/19/14 09:44 PM
04/19/14 09:44 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
A2
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609644
04/19/14 09:45 PM
04/19/14 09:45 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
This is a reproduction fuel pump but it's properly detailed, bolts included. I also have the original which has been restored but chose to stash it for the restoration engine I'm building (this is the stroker motor so it's going to get plenty of street time and will be using up wear items).
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609645
04/19/14 09:47 PM
04/19/14 09:47 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here's the fan pulley, the fan and clutch were not yet restored when these shots were taken. Bolts are correct and plated properly.
