SB water in oil / headgasket help #1609215
04/19/14 12:38 AM
04/19/14 12:38 AM
Blair, NE
cudacam Offline OP
cudacam  Offline OP
Blair, NE
E-Head SB got hot right before I put it away for the winter last year. (rad hose collapsed while idling, didn't catch it til it got over 260.) I've got some water in the oil now.
Leak down test:
1- 8% 2- 7%
3- 6% 4- 8%
5- 4% - and a few bubbles 6- 7%
7 -5% 8- 7%
even with the low number, bubbles from 5 in the radiator indicate that the heads need to come off, correct?
Re: SB water in oil / headgasket help [Re: cudacam] #1609216
04/19/14 12:55 AM
04/19/14 12:55 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Yes, the water in the oil should be reason enough.
Re: SB water in oil / headgasket help [Re: cudacam] #1609217
04/19/14 12:57 AM
04/19/14 12:57 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
my vote, it needs to come off. Check the head good with a rigid straight edge to make sure nothing has warped, and if good, throw on a new gasket, best case. Good luck
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: SB water in oil / headgasket help [Re: cudacam] #1609218
04/19/14 01:04 AM
04/19/14 01:04 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Number 5 is suspect, but do not
overlook the timing cover passages as a source of coolant in
t the oil. keep us posted
Re: SB water in oil / headgasket help [Re: TJP] #1609219
04/19/14 11:06 AM
04/19/14 11:06 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Is it clear water (condensation) or coolant?? Big difference. Know which before taking apart. Is the coolant level down????
Re: SB water in oil / headgasket help [Re: MoparforLife] #1609220
04/19/14 11:54 AM
04/19/14 11:54 AM
Blair, NE
cudacam Offline OP
cudacam  Offline OP
Blair, NE
Coolant was down close to 2". Oil was quite milky and up on the dipstick close to an extra quart.
I drained the pan, put in new oil and filter and ran it up to temp yesterday. some white smoke for a bit (looked like heavy condensation from pipes) then closer to normal after several min or so. oil and cooalnt levels looked stable after taking it up to temp. plugs look all about the same. I was thinking about the timing cover, but then the air through 5...
