Re: tunnel ram vs. single plane
[Re: AndyF]
#1608982
04/20/14 10:54 PM
04/20/14 10:54 PM
Posts: 1,301 Penna
70satelliteguy
Penna
"I think that is a good tunnel ram so you will probably be hard pressed to beat the power with a single plane intake. But I've run more than few dyno tests where the tunnel ram is a dog. Some of the old school tunnel rams are very weak when compared to a good single plane intake." I am Currently running the Indy 3X with a Quick fuel 1250 on my 572.It runs pretty good! If I did not have so much invested already I might be tempted to try a tunnel ram but I would want to pick up a lot more than a tenth or so or "The juice would not be worth the squeeze" for me! I do think they look awesome though! Mike ![](/ubbthreads/images/graemlins/beer.gif)
[Re: 79410aspenrt]
#1608984
04/21/14 09:01 AM
04/21/14 09:01 AM
Posts: 20,673 in a cattle trailer down by th...
Guitar Jones
do you guys think it would be worth putting 750's on instead of the 650's?
Yes I do.
[Re: Harley]
#1608989
04/21/14 07:00 PM
04/21/14 07:00 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
I went 2 tenths faster with the tunnel ram over my single 850.
Car looks good harley ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: joedust451]
#1608990
04/21/14 09:30 PM
04/21/14 09:30 PM
Posts: 251 Saskatchewan (SK)
79410aspenrt
Saskatchewan (SK)
I've had the tunnel ram on for 6 years, haven't tried a single plane or for that matter thought about it.
What kind of 750's should I look at? Holley, quick fuel, pro systems..........
[Re: 79410aspenrt]
#1608991
04/22/14 01:46 AM
04/22/14 01:46 AM
joedust451
super gas
super gas
Branson, Mo.
AED is getting a very reputation lately, might want to give them a call.
[Re: joedust451]
#1608992
04/22/14 01:40 PM
04/22/14 01:40 PM
Posts: 996 Queens, New York
Harley
Queens, New York
Thanks Joe. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: 79410aspenrt]
#1608996
04/22/14 09:44 PM
04/22/14 09:44 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
My custom built Quickfuel 750's had the wedge shaped tunnel ram floats, the carbs were pretty much dead-on right out of the box, never had to mess with idle or anything once it was set, best carbs I've ever owned.
[Re: ProSport]
#1608997
04/22/14 10:38 PM
04/22/14 10:38 PM
79410aspenrt
Saskatchewan (SK)
I run -8 braided line from tank to pump. from pump to regulator also -8 braided line. from regulator I run -6 to carbs.
Prosport, did you buy your quickfuel carbs from them or summit, jegs....?
what did they cost?
