Page 2 of 3 1 2 3
Re: tunnel ram vs. single plane [Re: ProSport] #1608980
04/20/14 08:38 PM
04/20/14 08:38 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
I have been running tunnel rams on engines for more than 30yrs. THEY will almost always make more power! In fact every one that I have done made more. Currently, I have one on a bb with rpm heads and a flat tappet cam running a best of 5.88 at almost 117mph footbraking. I am anxious to see what it does when we transbrake it. that equates to about 750hp. car weighs about 2850
Re: tunnel ram vs. single plane [Re: ProSport] #1608981
04/20/14 08:42 PM
04/20/14 08:42 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Its hard to beat the Weiand street TR with the D shaped ports, I ran a solid tenth & 1.1/2 MPH quicker over an M-1 single & 750 PF carb, & that was with minor tuning on 2 crappy 600 1850 holleys. On top of that, my 60ft. fell off by .03-.04 on the runs from the added torque & lack of a good suspension, plugs were stone white back in the pits.
Ran a 10.87 @ 123.58 on a 1.628 60ft. with TR
Ran a best of 10.98 @ 122.09 on a 1.58 in same air.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: tunnel ram vs. single plane [Re: AndyF] #1608982
04/20/14 10:54 PM
04/20/14 10:54 PM
Penna
70satelliteguy Offline
Penna
"I think that is a good tunnel ram so you will probably be hard pressed to beat the power with a single plane intake. But I've run more than few dyno tests where the tunnel ram is a dog. Some of the old school tunnel rams are very weak when compared to a good single plane intake."
I am Currently running the Indy 3X with a Quick fuel 1250 on my 572.It runs pretty good! If I did not have so much invested already I might be tempted to try a tunnel ram but I would want to pick up a lot more than a tenth or so or "The juice would not be worth the squeeze" for me! I do think they look awesome though!
Mike
Re: tunnel ram vs. single plane [Re: 70satelliteguy] #1608983
04/21/14 01:07 AM
04/21/14 01:07 AM
Saskatchewan (SK)
79410aspenrt Offline OP
Saskatchewan (SK)
do you guys think it would be worth putting 750's on instead of the 650's?
Re: tunnel ram vs. single plane [Re: 79410aspenrt] #1608984
04/21/14 09:01 AM
04/21/14 09:01 AM
Guitar Jones Offline
Yes I do.
Re: tunnel ram vs. single plane [Re: Guitar Jones] #1608985
04/21/14 12:03 PM
04/21/14 12:03 PM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
Whats the best small block TR non W head that is available.
Re: tunnel ram vs. single plane [Re: joes68340s] #1608986
04/21/14 02:45 PM
04/21/14 02:45 PM
Earth
Rob C Offline
Rob C  Offline
Earth
Great question. The answer could be dependent on the build particulars?
My M1 TR has short-ish looking runners and a lot of plenum.
Re: tunnel ram vs. single plane [Re: joes68340s] #1608987
04/21/14 03:02 PM
04/21/14 03:02 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Looks like this works good.
http://www.forabodiesonly.com/mopar/showthread.php?t=154106
I'd PM DJVCUDA, He has alot of know how with TRs on SBs.
Re: tunnel ram vs. single plane [Re: joedust451] #1608988
04/21/14 06:41 PM
04/21/14 06:41 PM
Queens, New York
Harley Offline
Harley  Offline
Queens, New York
I went 2 tenths faster with the tunnel ram over my single 850.
Re: tunnel ram vs. single plane [Re: Harley] #1608989
04/21/14 07:00 PM
04/21/14 07:00 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Car looks good harley
Re: tunnel ram vs. single plane [Re: joedust451] #1608990
04/21/14 09:30 PM
04/21/14 09:30 PM
Saskatchewan (SK)
Saskatchewan (SK)
I've had the tunnel ram on for 6 years, haven't tried a single plane or for that matter thought about it.
What kind of 750's should I look at? Holley, quick fuel, pro systems..........
Re: tunnel ram vs. single plane [Re: 79410aspenrt] #1608991
04/22/14 01:46 AM
04/22/14 01:46 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
AED is getting a very reputation lately, might want to give them a call.
Re: tunnel ram vs. single plane [Re: joedust451] #1608992
04/22/14 01:40 PM
04/22/14 01:40 PM
Queens, New York
Harley Offline
Harley  Offline
Queens, New York
Thanks Joe.
Re: tunnel ram vs. single plane [Re: Harley] #1608993
04/22/14 09:09 PM
04/22/14 09:09 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
What are you guys running for fuel line on these dual carb applications?
I was planning on -10 from tank to pump, -8 from pump to regulator (two port) and -6 to each carb (3/8" hard line to each bowl). Would I be Better off running a four port regulator with -6 to each bowl? Carbs are 4150's and the combo should make 700-750 on pump gas.
Re: tunnel ram vs. single plane [Re: Jeremiah] #1608994
04/22/14 09:21 PM
04/22/14 09:21 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
I am running 2 dash 8 lines into my Holley block pump, then dash 8 up to my Holley billet 4 port fuel reg and then 4 dash 6 lines to each fuel bowl.here is a pick of how i got mine set up. lets see if the pic will post.i am no carb person but it sounds like it would be better to me to run a line to each carb bowl. mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: tunnel ram vs. single plane [Re: Guitar Jones] #1608995
04/22/14 09:25 PM
04/22/14 09:25 PM
mopar65 Offline
mopar65  Offline
One tip I can give you is don't use any power valves.
why do you recommend not to use power valves?
Re: tunnel ram vs. single plane [Re: 79410aspenrt] #1608996
04/22/14 09:44 PM
04/22/14 09:44 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
My custom built Quickfuel 750's had the wedge shaped tunnel ram floats, the carbs were pretty much dead-on right out of the box, never had to mess with idle or anything once it was set, best carbs I've ever owned.
Re: tunnel ram vs. single plane [Re: ProSport] #1608997
04/22/14 10:38 PM
04/22/14 10:38 PM
Saskatchewan (SK)
Saskatchewan (SK)
I run -8 braided line from tank to pump. from pump to regulator also -8 braided line. from regulator I run -6 to carbs.
Prosport, did you buy your quickfuel carbs from them or summit, jegs....?
what did they cost?
Re: tunnel ram vs. single plane [Re: 79410aspenrt] #1608998
04/22/14 11:00 PM
04/22/14 11:00 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
So is the consensus that something like this won't work for fuel lines?
Re: tunnel ram vs. single plane [Re: Jeremiah] #1608999
04/22/14 11:27 PM
04/22/14 11:27 PM
Saskatchewan (SK)
Saskatchewan (SK)
yes that will work just fine. I used that set up a few years ago on my big block with a 671 blower.
Page 2 of 3 1 2 3
