Re: Wrong Master Cylinder? E-body Power Brakes - Disc/Drum
[Re: Steve Bryant]
#1608799
04/17/14 11:07 PM
04/17/14 11:07 PM
RapidRobert
I'm assuming the rear drums are up & pulling on the ebrake will ans that Q in seconds. When they pump up do they have to be pumped up again shortly thereafter? I'm assuming you bled the MC first before starting on the corners? Is the rounded pushrod nub a hair away from the bottom of the MC piston recess "the thimble"? You might grab a pair of brass inverted flare male brass fittings at the Edelman cabinet at your parts house & cap the MC ports (they're cheap & you will reuse em in the future). Then with it capped/idling if the pedal is rock hard with virtually no travel then the MC is good & the MC is bled out then uncap the drum half & hook it up & bleed it out till the pedal is hard then connect/bleed the front discs.
[Re: MCTPhoenix]
#1608801
04/18/14 04:08 AM
04/18/14 04:08 AM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Just a thought.The calipers are installed with the bleeder up? Seen it before.
Leave the gun.......take the Cannoli's....Mike
[Re: Steve Bryant]
#1608804
04/18/14 05:35 PM
04/18/14 05:35 PM
RapidRobert
They are straight threads so I would measure the OD & I would assume that they ain't fine threads. What I would do is grab a bolt out of your junk that fits. As you know it is an inverted flare fitting if that might help on finding the correct thread type so you can let your fingers do the walking & order it by ph or online. Holler how things turn out
[Re: Steve Bryant]
#1608805
04/18/14 06:29 PM
04/18/14 06:29 PM
Posts: 18,160 Mass
DAYCLONA
Mass
What's the masters application?....did you bench bleed the master before connecting it to the system?, calipers,Stock, aftermarket? pin style, floaters?, proportioning valve?, distribution block?, is this a recent drum/drum to disc/drum swap?, ...some background on your set up rather than 50 questions trying to determine what you have, helps us, help you
Mike
[Re: Steve Bryant]
#1608807
04/18/14 09:17 PM
04/18/14 09:17 PM
RapidRobert
With the front discs capped is the pedal hard? If not I would keep the front disc half capped & bleed out the rear drums (pull the ebrake will help you with them) till they're good. If yes (pedal hard which means the drums are bled) I'd work on the discs & pumping the pedal fast 3 times then having a helper open the bleeder on the 4th downstroke helps agitate the fluid & get the air out. Perfect verbal timing with the helper. Put a block of wood of the right thickness under the brake pedal to limit its' travel to the normal range & it makes it easier for you to come to a dead stop. On a real tough case you might need to take off the caliper(s) & block the piston solid then tilt it as needed till the air is out. Just cause the bleeder is up does not neccessarily mean where the passage meets the bore that that point is at 12 o'clock. Most times agitating the fluid will get the air out. No need to undo the prop etc line fittings as long as the fittings are tight/no leaks
[Re: Steve Bryant]
#1608811
04/18/14 11:45 PM
04/18/14 11:45 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Just to reaffirm your bleeding technique, when doing the rears, your starting from the passenger side correct, then moving over to the drivers rear?...your assistant is fully aware of the proper pumping pedal/hold procedure as you bleed the brakes (as I've gone thru this "ordeal" many times with an assistant, only to find they are the culprit in improperly bleeding a system)...when you bleed the fronts, your starting with the passenger side and finishing with the drivers correct?
On another note, sometimes disc calipers have casting voids that retain air during the bleeding process, only to release it later, causing the system to fail...one remedy, is to remove te caliper from it's mount, use a C clamp and carefully collapse the piston, slowly bottoming it out in it's bore (watch the fluid level in the master when doing this) then SLOWLY and with little pedal pressure bleed the caliper(s) one at a time with the C clamp keeping the caliper piston compressed, this will eliminate any trapped air in a casting void...
Another thing to consider, is the fluid,... are you returning the "pumped" and collected/bleed fluid back into the system?, if so if may have been aerated with micro bubbles, that when under compression in the system cause a "spongy" pedal, bleed fluid should not be returned to the system,
Hope this might help, I know bleeding any hyd. system can sometimes be fraught with headaches
Mike
