Page 3 of 3 1 2 3
Re: Leaking '70 repop disc brake metering valve [Re: sah62] #1607107
04/23/14 09:33 PM
04/23/14 09:33 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I made some more changes to the way to site presents certificates. Any better?
I think you've solved the issue...Went right to the site with no flags...
Re: Leaking '70 repop disc brake metering valve [Re: screamindriver] #1607108
04/23/14 10:00 PM
04/23/14 10:00 PM
Virginia, USA
sah62 Offline
sah62  Offline
Virginia, USA
Great! Thanks for the feedback and help in fixing the problem.
Scott Hollenbeck Administrator, Mustang 428 Cobra Jet Registry Owner, Muscle Car Research LLC 1970 Ford Mustang Mach 1 2006 Dodge Charger SRT8 1995 Chevrolet Impala SS
Re: Leaking '70 repop disc brake metering valve [Re: sah62] #1607109
04/24/14 10:11 PM
04/24/14 10:11 PM
Canal Fulton, (Akron) Ohio
Q
Quicksmopars Offline
Q
Mine is from Fine Lines and is leaking from the bottom hex plug. I tightened the crap out of it and still leaks. I may try teflon tape this weekend. Luckily I'm running DOT5 or my paint would be gone! I'll let you know if it fixes it.
Page 3 of 3 1 2 3
