Page 2 of 3 1 2 3
Re: Leaking '70 repop disc brake metering valve [Re: 70runner] #1607087
04/20/14 03:46 PM
04/20/14 03:46 PM
Jacksonville, Fl
426runner Offline OP
Jacksonville, Fl
Ordered a new metering valve from Fine Lines, installed it yesterday... no leaks. It looks like the fellas over at Fine Lines give a crap.
Later, Sandy '70 HEMI Road Runner B5/B5, 4 spd "Sandy's Garage" on Facebook
Re: Leaking '70 repop disc brake metering valve [Re: 426runner] #1607088
04/21/14 02:17 PM
04/21/14 02:17 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
After adding the teflon tape to the male threads at both ends of the metering valve, mine did not leak after driving it over the weekend.
Thanks for the tip!!
Re: Leaking '70 repop disc brake metering valve [Re: screamindriver] #1607089
04/21/14 10:40 PM
04/21/14 10:40 PM
Virginia, USA
sah62 Offline
sah62  Offline
Virginia, USA
Scott..I can't open either of the links...Something about the websites security certificate being under another site's address ???? I'm sure this is diverting alot of potential customers..
It would be helpful if you could somehow send me a copy of whatever you're seeing. As far as I can tell the certificates for the site are properly configured.
Scott Hollenbeck Administrator, Mustang 428 Cobra Jet Registry Owner, Muscle Car Research LLC 1970 Ford Mustang Mach 1 2006 Dodge Charger SRT8 1995 Chevrolet Impala SS
Re: Leaking '70 repop disc brake metering valve [Re: sah62] #1607090
04/21/14 10:52 PM
04/21/14 10:52 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
Your link opens correctly for me.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: Leaking '70 repop disc brake metering valve [Re: screamindriver] #1607091
04/22/14 08:53 AM
04/22/14 08:53 AM
MA
steve70 Offline
steve70  Offline
MA
Scott, I get the same website warning.
1970 Challenger T/A 4 speed
Re: Leaking '70 repop disc brake metering valve [Re: steve70] #1607092
04/22/14 07:50 PM
04/22/14 07:50 PM
Virginia, USA
sah62 Offline
sah62  Offline
Virginia, USA
Could you please click on that "More Information" link and show me what you see? That looks like Internet Explorer, but which browser (name and version) are you using?
Re: Leaking '70 repop disc brake metering valve [Re: sah62] #1607093
04/22/14 09:15 PM
04/22/14 09:15 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Here's an old link I had from the place that sells rebuild kits https://www.musclecarresearch.com/1970-76-mopar-combo-valve-autopsy
The web site mentioned above is mine. Here's a direct link to the kit I have to re-seal that valve:
https://www.musclecarresearch.com/mopar-seal-kit-2
Both these links open instantly for me with no issues, perhaps it's the programs/format that some PC's are running?
I'm running Windows 8 w/ Mozilla FireFox, and Norton 360 security
Re: Leaking '70 repop disc brake metering valve [Re: sah62] #1607094
04/22/14 10:06 PM
04/22/14 10:06 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I'm using internet explorer 9...it's generating the warning..
Re: Leaking '70 repop disc brake metering valve [Re: 426runner] #1607095
04/23/14 01:48 AM
04/23/14 01:48 AM
California
cudagee Offline
cudagee  Offline
California
I bought an aftermarket one too and took it for a test drive and I almost totaled my friends conv Challenger...not to mention the brake fluid ruined the new paint on the frame. I took it off and installed a used oem part.
Re: Leaking '70 repop disc brake metering valve [Re: 426runner] #1607096
04/23/14 01:52 AM
04/23/14 01:52 AM
California
cudagee Offline
cudagee  Offline
California
I bought an aftermarket one to and took it for a test drive and I almost totaled my friends conv Challenger...not to mention the brake fluid ruined the new paint on the frame. I took it off and installed a used oem part.
Re: Leaking '70 repop disc brake metering valve [Re: screamindriver] #1607097
04/23/14 08:06 AM
04/23/14 08:06 AM
Virginia, USA
sah62 Offline
sah62  Offline
Virginia, USA
OK, but what do you see when you click on that "More information" link? I really need to see what IE thinks the certificate chain looks like.
Re: Leaking '70 repop disc brake metering valve [Re: sah62] #1607098
04/23/14 08:21 AM
04/23/14 08:21 AM
MA
steve70 Offline
steve70  Offline
MA
I'm using Internet Explorer 10. Here's the warning
Re: Leaking '70 repop disc brake metering valve [Re: steve70] #1607099
04/23/14 09:10 AM
04/23/14 09:10 AM
Virginia, USA
sah62 Offline
sah62  Offline
Virginia, USA
Thanks! Hmm, that's not helpful at all. Let's try another tactic.
Please click on "Continue to this website (not recommended)". When you do you should see a "Certificate error" button next to the address bar. Click on the "Certificate error" button. A new window should pop up with more information about the error. In that window you should see a "View certificates" link. Click on that link. It should identify the site for which the certificate was issued, and the name you see *should* be musclecarresearch.com. If that's what you see the problem is most definitely in the way your browser is processing the certicate. I don't know why it's complaining, but it shouldn't be. See if these URLs eliminate the problem:
https://musclecarresearch.com/1970-76-mopar-combo-valve-autopsy
https://musclecarresearch.com/mopar-seal-kit-2
Re: Leaking '70 repop disc brake metering valve [Re: sah62] #1607100
04/23/14 09:31 AM
04/23/14 09:31 AM
MA
steve70 Offline
steve70  Offline
MA
Here's the certificate
Re: Leaking '70 repop disc brake metering valve [Re: steve70] #1607101
04/23/14 10:04 AM
04/23/14 10:04 AM
Virginia, USA
sah62 Offline
sah62  Offline
Virginia, USA
Thanks! I have no idea why my web server gave you the certificate for musclecarresearch.net (I use that domain for management purposes), but I just made some changes to the server config in an attempt to address the issue. Can you try again?
Re: Leaking '70 repop disc brake metering valve [Re: sah62] #1607102
04/23/14 10:27 AM
04/23/14 10:27 AM
MA
steve70 Offline
steve70  Offline
MA
It's till comes up with the same error
Re: Leaking '70 repop disc brake metering valve [Re: steve70] #1607103
04/23/14 10:35 AM
04/23/14 10:35 AM
Virginia, USA
sah62 Offline
sah62  Offline
Virginia, USA
OK, with some more research I think I know what's going on. Which version of Windows are you running?
Re: Leaking '70 repop disc brake metering valve [Re: sah62] #1607104
04/23/14 12:12 PM
04/23/14 12:12 PM
MA
steve70 Offline
steve70  Offline
MA
Windows 7, 64 bit and Internet Explorer 10
Re: Leaking '70 repop disc brake metering valve [Re: steve70] #1607105
04/23/14 02:39 PM
04/23/14 02:39 PM
Virginia, USA
sah62 Offline
sah62  Offline
Virginia, USA
I made some more changes to the way to site presents certificates. Any better?
Re: Leaking '70 repop disc brake metering valve [Re: sah62] #1607106
04/23/14 09:22 PM
04/23/14 09:22 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
No problem seeing either website page...
Windows 8, 64 Bit, McAfee Security Center, Mozilla Firefox
Page 2 of 3 1 2 3
