Re: Leaking '70 repop disc brake metering valve
[Re: 426runner]
#1607088
04/21/14 02:17 PM
04/21/14 02:17 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
After adding the teflon tape to the male threads at both ends of the metering valve, mine did not leak after driving it over the weekend. Thanks for the tip!!
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: steve70]
#1607092
04/22/14 07:50 PM
04/22/14 07:50 PM
Posts: 32 Virginia, USA
sah62
Virginia, USA
Could you please click on that "More Information" link and show me what you see? That looks like Internet Explorer, but which browser (name and version) are you using?
Scott Hollenbeck
Administrator, Mustang 428 Cobra Jet Registry
Owner, Muscle Car Research LLC
1970 Ford Mustang Mach 1
2006 Dodge Charger SRT8
1995 Chevrolet Impala SS
[Re: sah62]
#1607094
04/22/14 10:06 PM
04/22/14 10:06 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
I'm using internet explorer 9...it's generating the warning..
[Re: steve70]
#1607099
04/23/14 09:10 AM
04/23/14 09:10 AM
sah62
Virginia, USA
Thanks! Hmm, that's not helpful at all. Let's try another tactic. Please click on "Continue to this website (not recommended)". When you do you should see a "Certificate error" button next to the address bar. Click on the "Certificate error" button. A new window should pop up with more information about the error. In that window you should see a "View certificates" link. Click on that link. It should identify the site for which the certificate was issued, and the name you see *should* be musclecarresearch.com. If that's what you see the problem is most definitely in the way your browser is processing the certicate. I don't know why it's complaining, but it shouldn't be. See if these URLs eliminate the problem: https://musclecarresearch.com/1970-76-mopar-combo-valve-autopsyhttps://musclecarresearch.com/mopar-seal-kit-2
Scott Hollenbeck
[Re: steve70]
#1607101
04/23/14 10:04 AM
04/23/14 10:04 AM
sah62
Virginia, USA
Thanks! I have no idea why my web server gave you the certificate for musclecarresearch.net (I use that domain for management purposes), but I just made some changes to the server config in an attempt to address the issue. Can you try again?
Scott Hollenbeck
[Re: sah62]
#1607102
04/23/14 10:27 AM
04/23/14 10:27 AM
Posts: 892 MA
steve70
MA
It's till comes up with the same error
1970 Challenger T/A 4 speed
[Re: steve70]
#1607103
04/23/14 10:35 AM
04/23/14 10:35 AM
sah62
Virginia, USA
OK, with some more research I think I know what's going on. Which version of Windows are you running?
Scott Hollenbeck
[Re: sah62]
#1607104
04/23/14 12:12 PM
04/23/14 12:12 PM
Posts: 892 MA
steve70
MA
Windows 7, 64 bit and Internet Explorer 10
[Re: steve70]
#1607105
04/23/14 02:39 PM
04/23/14 02:39 PM
sah62
Virginia, USA
I made some more changes to the way to site presents certificates. Any better?
Scott Hollenbeck
[Re: sah62]
#1607106
04/23/14 09:22 PM
04/23/14 09:22 PM
Posts: 3,624 Fort Worth, Texas
xs29j8
Fort Worth, Texas
No problem seeing either website page...
Windows 8, 64 Bit, McAfee Security Center, Mozilla Firefox
