2001 T&C VAN: Security Warning #1606860
04/13/14 04:09 PM
04/13/14 04:09 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
Kinda long, but was asked this AM. These folks bought a used TnC Minivan. Ran fine for a day or 2, but they got an alarm about the security, and it would only run 3 sec's, start and run 3 sec's, then quit, would always restart but just die.
Then it'd go awhile and not have any problem. Then start acting up again.
Clues? I've seem to have read similar problems here.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: 2001 T&C VAN: Security Warning [Re: Magnumguy] #1606861
04/13/14 06:05 PM
04/13/14 06:05 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Are they using the same key?
Do they have more than one programmed key on the key chain?
Possible bad skim module and or key.
Re: 2001 T&C VAN: Security Warning [Re: Todd] #1606862
04/13/14 06:21 PM
04/13/14 06:21 PM
S.E.Ohio
S.E.Ohio
is it a big deal to fix?
Re: 2001 T&C VAN: Security Warning [Re: Magnumguy] #1606863
04/15/14 12:08 AM
04/15/14 12:08 AM
S.E.Ohio
S.E.Ohio
Re: 2001 T&C VAN: Security Warning [Re: Magnumguy] #1606864
04/15/14 07:07 PM
04/15/14 07:07 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Dealer or someone with a DRBIII. Need to get the DTC's read in the skim. That should get you in the right direction.
Re: 2001 T&C VAN: Security Warning [Re: Todd] #1606865
04/16/14 09:40 PM
04/16/14 09:40 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
yep, anything else is guessing
Re: 2001 T&C VAN: Security Warning [Re: gtx6970] #1606866
04/20/14 12:11 PM
04/20/14 12:11 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
programing needs to be done after replacing a component (scan tool is required)
