Re: Trans Am E-body roll cage pics?
[Re: jcc]
#1606608
06/13/14 11:32 PM
06/13/14 11:32 PM
Posts: 23,908 Here
jcc
No soup for you!!!
No soup for you!!!
Here
Captive spring loaded lug nuts, last one
I forbid my content here from being learned and used by artificial intelligence systems.
[Re: jcc]
#1606610
07/07/14 12:12 AM
07/07/14 12:12 AM
Posts: 813 Ontario,Canada
brads70
Ontario,Canada
That would never fly on any modern racecar!
[Re: RylisPro]
#1606614
07/11/14 10:08 PM
07/11/14 10:08 PM
Posts: 23,908 Here
jcc
No soup for you!!!
No soup for you!!!
Here
I see your main rollbar diagnol is the now preferred one piece. Since you are 75% finished, this is a leaf spring or a 4 link rear chassis, because your rear down bars are not to the rear? I also like personally but seldom see it, but a low as possible bar tying both of the bottom legs of the main hoop together, any side impact would without any lower bar would depend solely on the chassis sheet metal floor with a large DS tunnel in the middle, and a bent OEM crossmember, not a lot of protection for the occupants, IMO, and easy to install this additional bar.
[Re: jcc]
#1606616
07/17/14 11:44 AM
07/17/14 11:44 AM
Posts: 5,408 Pikes Peak Country
TC@HP2
Pikes Peak Country
I noticed this too. Perfect arrangement for a coil over conversion, but less than ideal for a leaf spring car that is putting loads in to the rear most part of the sub-frame.
[Re: TC@HP2]
#2853580
11/30/20 08:58 PM
11/30/20 08:58 PM
Posts: 2,432 NorCal
RylisPro
NorCal
I see your main rollbar diagnol is the now preferred one piece. Since you are 75% finished, this is a leaf spring or a 4 link rear chassis, because your rear down bars are not to the rear? I noticed this too. Perfect arrangement for a coil over conversion, but less than ideal for a leaf spring car that is putting loads in to the rear most part of the sub-frame. For years I had thought that the roll cage in the `Cuda was built wrong when it came to the rear down tubes. It turns out that my roll cage is built correctly to SCCA specs which is from the main hoop 45° degrees to the wheel wells. I called two SCCA tech inspectors to verify this as well as tubing size specs, etc. Originally that's how All American Racers built the Trans Am cars were down tubes from the main hoop to rear leaf spring perch. What SCCA rules and engineering requires currently is down tubes from main hoop to go at 45° deg down to the wheel wells. That way in a rear end accident it can crumple the rear of the car without transferring additional force through the down tubes into the main hoop therefore not compromising/kinking the main hoop & halo. I also have a fuel cell cage back there to help absorb any rear impact. The reason I brought this thread back from the dead is just to clear up some confusion as I will be tig welding in the cage on the 73 Challenger build. Felt dumb for years thinking my cagebuilder installed it incorrectly when he was actually correct haha! I will also add in tubes that tie in the torsion bar crossmember which "mirrors" it inside the passenger compartment as well as a tube the ties both legs of the main hoop together. I'll get video to document and post it up on our YouTube channel next year. Still have to buy all the tube because I'm broke haha! Not pointing any one person out, just replying to the last post thanks!
[Re: RylisPro]
#2855622
12/05/20 10:13 AM
12/05/20 10:13 AM
Posts: 1,376 NORTHERN CA
HUSTLESTUFF
NORTHERN CA
I would put a bar from top of door bar, attached to main hoop and down rearward to frame rail in front of or next to wheel tub and add torque box. That way all rear end forces go into structure or at least help to stiffen the fronts mounts
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL RIP UN
[Re: RylisPro]
#2856260
12/06/20 08:22 PM
12/06/20 08:22 PM
TC@HP2
Pikes Peak Country
I see your main rollbar diagnol is the now preferred one piece. Since you are 75% finished, this is a leaf spring or a 4 link rear chassis, because your rear down bars are not to the rear? I noticed this too. Perfect arrangement for a coil over conversion, but less than ideal for a leaf spring car that is putting loads in to the rear most part of the sub-frame. For years I had thought that the roll cage in the `Cuda was built wrong when it came to the rear down tubes. It turns out that my roll cage is built correctly to SCCA specs which is from the main hoop 45° degrees to the wheel wells. I called two SCCA tech inspectors to verify this as well as tubing size specs, etc. Originally that's how All American Racers built the Trans Am cars were down tubes from the main hoop to rear leaf spring perch. What SCCA rules and engineering requires currently is down tubes from main hoop to go at 45° deg down to the wheel wells. That way in a rear end accident it can crumple the rear of the car without transferring additional force through the down tubes into the main hoop therefore not compromising/kinking the main hoop & halo. I also have a fuel cell cage back there to help absorb any rear impact. The reason I brought this thread back from the dead is just to clear up some confusion as I will be tig welding in the cage on the 73 Challenger build. Felt dumb for years thinking my cagebuilder installed it incorrectly when he was actually correct haha! I will also add in tubes that tie in the torsion bar crossmember which "mirrors" it inside the passenger compartment as well as a tube the ties both legs of the main hoop together. I'll get video to document and post it up on our YouTube channel next year. Still have to buy all the tube because I'm broke haha! Not pointing any one person out, just replying to the last post thanks! Things evolve, roll with the changes, learn new ways to go fast...
[Re: RylisPro]
#2856538
12/07/20 12:37 PM
12/07/20 12:37 PM
Posts: 23,908 Here
jcc
No soup for you!!!
No soup for you!!!
Here
" I also have a fuel cell cage back there to help absorb any rear impact." You put fuel in it? Sorry, I'd be much more concerned about a fuel fed fire ,then any rear crumple zone advantages. "
