Re: Performmer RPM Mdification
[Re: mopowers]
#1606460
04/12/14 09:44 PM
04/12/14 09:44 PM
RapidRobert
Yes people have cut down dividers that did make noticeable differences so I'm sure it would on the RPM. Actually you dont want to knife edge any edges below the carb base as once the air/fuel are mixed as any sharp edges can split air/fuel molecules away from each other & they need to be bonded in pairs to each other for them to ignite. Even if sharp edges only cause 1% of the mixture to not ignite that's 1% horsepower you lose. Knife edging (appropriately) up in the carb itself for more airflow is as you know beneficial (thinning throttle blades/reducing shaft diameter etc). No actual exp on how lowering the divider in an RPM would make it act. You want all edges (including the divider) smoothed/tapered appropriately as needed
[Re: screamindriver]
#1606462
04/12/14 11:50 PM
04/12/14 11:50 PM
Posts: 10,563 Rittman Ohio
fourgearsavoy
Rittman Ohio
I would leave it alone ![](/ubbthreads/images/graemlins/Twocents.gif) I just cleaned up a small amount casting flaws and bolted it on and ran 10.91 with a dual plane intake and that's not bad. Gus ![](/ubbthreads/images/graemlins/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: RapidRobert]
#1606463
04/13/14 03:52 AM
04/13/14 03:52 AM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
what if it splits both in half ??now you would have a more atomized mixture ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: ademon]
#1606465
04/13/14 11:39 AM
04/13/14 11:39 AM
RapidRobert
what if it splits both in half? now you would have a more atomized mixture
The manifold sharp metal edges are only capable of seperating the molecules away from each other.
[Re: RapidRobert]
#1606466
04/13/14 11:42 AM
04/13/14 11:42 AM
Posts: 75,134 A Banana Republic near you.
JohnRR
Did you really just type that ??? ![](/ubbthreads/images/graemlins/shock.gif)
[Re: RapidRobert]
#1606469
04/14/14 12:37 PM
04/14/14 12:37 PM
Posts: 3,399 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
yes I did. I believe every little bit (of blueprinting) adds up & keeps us ahead of the chebrolet boys
I'm not a professional chemist, but I think some of your science is a little flawed...
An atomized mixture simply means that tiny droplets of a liquid (fuel) are dispersed in a gas(air). They do not chemically bond, as this would create an entirely different molecule.
Also, for your "pairs" concept to be correct, air and fuel molecules would have to be in a 1:1 ratio. They are not.
And if a sharp edge on an intake manifold were capable of spltting atoms apart, let's just say atomic bombs would be a lot easier to make.
The main thing you want in a "wet" intake manifold is for the air/fuel to move quickly and smoothly through, so the tiny droplets stay evenly distributed and do not fall out of suspension.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: RapidRobert]
#1606471
04/14/14 06:51 PM
04/14/14 06:51 PM
JohnRR
(1) well I did play hookey from several of my high school chemistry classes (2) not splitting atoms but seperating (not splitting) A/F molecules away from each other. Smoothed passages (rougher finish on intake path)/no sharp edges/manipulating velocity with porting
How sharp an edge are we talking here that can split something that usually can only be seen using a $500k piece of equipment ???
[Re: Rob C]
#1606475
04/14/14 10:34 PM
04/14/14 10:34 PM
Posts: 4,799 ILL
MLR426
ILL
Splitting molocules ![](/ubbthreads/images/graemlins/laugh2.gif) the divider should split the fuel and air charge coming in but it does know a red molocule from a blue molocule, did I just write that LOL. I'm done with this post now. MLR426
[Re: MLR426]
#1606476
04/14/14 10:40 PM
04/14/14 10:40 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
Splitting molocules the divider should split the fuel and air charge coming in but it does know a red molocule from a blue molocule, did I just write that LOL. I'm done this post now.
MLR426
It's the new version of the old edelbrock.
Einstein Performer RPM... The power of e=mc2 LOL
