A Body Upper Ball Joint Question #1606429
04/12/14 08:04 PM
04/12/14 08:04 PM
McHenry, Illinois
RAUPLEMINZE454 Offline OP
McHenry, Illinois
Hey Guys,
Is there supposed to be a washer in between the castle nut and the dust boot?
Thanks in advance,
Brian
Re: A Body Upper Ball Joint Question [Re: RAUPLEMINZE454] #1606430
04/12/14 08:10 PM
04/12/14 08:10 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The boot should cover the ball joint and the stud then sticks through the spindle with no washer just the nut.
Re: A Body Upper Ball Joint Question [Re: stumpy] #1606431
04/12/14 10:22 PM
04/12/14 10:22 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Only the spindle is between the castle nut and the dust boot.
Re: A Body Upper Ball Joint Question [Re: nomore65BelvJim] #1606432
04/18/14 07:38 PM
04/18/14 07:38 PM
McHenry, Illinois
McHenry, Illinois
Thanks guys!!!
Re: A Body Upper Ball Joint Question [Re: RAUPLEMINZE454] #1606433
04/19/14 02:34 PM
04/19/14 02:34 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Apparently this differs with the manufacturer, if the nut bottoms before getting tight or if the cotter pin hole is too high in the castle nut, a washer is needed.
