Re: Broken oil pickup removal
[Re: Challenger 1]
#1606306
04/15/14 03:35 PM
04/15/14 03:35 PM
Posts: 75,126 A Banana Republic near you.
JohnRR
Then I went to external belt driven oil pumps with a wet sump pan because it is more reliable than a screwed in pickup or welded in like mine were pickups.
Are you running this setup in your STREET CARS ??
[Re: JohnRR]
#1606307
04/15/14 04:07 PM
04/15/14 04:07 PM
Challenger 1
Cincinnati, Ohio
No but a 500+hp hemi should be able to put down some power and maybe shake the tires even on the street?
[Re: Challenger 1]
#1606308
04/15/14 04:55 PM
04/15/14 04:55 PM
JohnRR
Are you suggesting that the OP, and anyone else reading, run a belt driven oil pump system ?
[Re: JohnRR]
#1606309
04/15/14 06:23 PM
04/15/14 06:23 PM
Posts: 4,179 California
mickm
California
i doubt he is, just relating what he did.
i have no problems putting another pickup in there and carrying on. i may use the milodon pickup that i got in vegas as opposed to the stock replacement though. i still haven't got to it, but i suspect i'll see some marks on the bottom inside of my pan, showing that when the engine fell/dropped onto the pan it tweaked the pickup a bit, and just took this much time to do its thing.
[Re: JohnRR]
#1606310
04/15/14 06:25 PM
04/15/14 06:25 PM
Challenger 1
Cincinnati, Ohio
No I'm not, as the hemi already has a external oil pump unlike the BBC where there are many advantages to a external oil pump.
[Re: mickm]
#1606311
04/15/14 08:22 PM
04/15/14 08:22 PM
Posts: 3,291 West Coast, USA
jbc426
West Coast, USA
I told you to quit doing wheelies!
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#1606312
04/15/14 08:45 PM
04/15/14 08:45 PM
mickm
California
![](/ubbthreads/images/graemlins/drive.gif)
Re: Broken oil pickup removal *UPDATE*
[Re: mickm]
#1606314
04/16/14 03:12 AM
04/16/14 03:12 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Engine autopsy without any clear cause of failure is the worst. This is the lesser of the evils. By Easter you should be ripping gears again, huh? ![](/ubbthreads/images/graemlins/drive.gif)
[Re: Kern Dog]
#1606315
04/16/14 04:22 AM
04/16/14 04:22 AM
mickm
California
depends when easter is...
[Re: Lee446]
#1606320
04/20/14 12:51 AM
04/20/14 12:51 AM
Posts: 16,168 Mesa, Arizona
dart4forte
Mesa, Arizona
Mick, that sure does not seem like enough of the pickup tube is engaged in the block. It looks like only about four threads. You may want to chase the threads with the proper tap.
Wow, have to Still you dodged a big bullet
[Re: Lee446]
#1606321
04/20/14 04:14 AM
04/20/14 04:14 AM
mickm
California
i'll have to ask my friend where the crack was to make sure. i think there was another 1-2 threads in the block where it broke off.
i will look into this. it is clear though that the problem was the pan hitting the pickup. there is a nice imprint of the pickup on the bottom of the pan.
how many threads is a separate issue, so i will check into that...
