Header and exhaust system, A body #1605610
04/10/14 10:58 PM
04/10/14 10:58 PM
Ottawa, ontario
dd340 Offline OP
dd340  Offline OP
Ottawa, ontario
I'm looking at headers and exhaust for my 69 dart. Right now I'm using the original system with 340 manifolds but I think I would like to upgrade to headers and a full 2 1/2 system. Any suggestions. Doug's headers seem to have a good reputation but what about pipes?
Re: Header and exhaust system, A body [Re: dd340] #1605611
04/10/14 11:29 PM
04/10/14 11:29 PM
Any suggestions.
Mandrel bends. X pipe system. In addition to your choice of regular mufflers up front, additionally running some glasspacks alongside the rear leafs for addit'l noise control will let you run less restrictive (louder) muffs up front for more power from an overall less restrictive exhaust system with the noise level being tolerable. If you do go with the rear glasspacks choose quality ones that do not neck down on the ends where the nipples are welded to the case
