For street driving and cornering the higher spring rates help a lot, especially with the heavier engine. Newer performance cars run much higher rates than 60'/70's MOPARs as part of a "balanced package" and drive well. In general, the T bar front suspension responds very well to improvements.
Getting the balance is the key. With your goals, suggest at least the .94 bars, good replacement gas shocks and factory or better front sway bar. If you want to step it up in handling, I'd suggest stiffening with welded frame connectors as a first step, 1" T bars, high end shocks and bigger front sway bar. A fully welded/gusseted K frame and gusseted LCA helps also.
