painting an assembled alternator? #1605005
04/08/14 07:53 PM
04/08/14 07:53 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
lets discuss,
will it affect operation?
Re: painting an assembled alternator? [Re: mcat4321] #1605006
04/08/14 09:06 PM
04/08/14 09:06 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
But why?
Re: painting an assembled alternator? [Re: 71birdJ68] #1605007
04/08/14 10:38 PM
04/08/14 10:38 PM
Detroit Michigan
stinger Offline
stinger  Offline
Detroit Michigan
I cleared one,worked for years and still worked before I pulled it for an upgrade.
Re: painting an assembled alternator? [Re: mcat4321] #1605008
04/08/14 10:39 PM
04/08/14 10:39 PM
As you know 90% of sucessful painting is in the prep (cleanliness/right grit of surface sanding). wouldn't affect operation. You'd wanna take it apart to do a primo job
Re: painting an assembled alternator? [Re: RapidRobert] #1605009
04/09/14 12:19 AM
04/09/14 12:19 AM
IN
ahy Offline
ahy  Offline
IN
I prepped one really well for paint once and got a great paint job on it. Prep included spray solvent to get it clean. Later I found that spray solvent and the insulation on the wires inside don't get along. The alternator failed on a road trip. I got home but its a very long (and fun) story. My advice is to either leave it alone or buy a painted or plated alternator from a rebuilder or new. Don't try to DIY.
