Me thinks the E-Brake cable is installed wrong
#1604953
04/08/14 07:29 PM
04/08/14 07:29 PM
Posts: 5,912 Athens, Greece
Pyper70
Athens, Greece
The patient...
1972 Roadrunner 440/4spd
I crawled under neath today to take off the torsion bar in an effort to do the front suspension...instantly...my eyes locked on to the E-Brake cable management / routing. There are four spacers connected on a J bolt in an effort to apply tension to the rear brakes.
Anyone have a correct way of how this is done. I am prettttttty sure this isn't the way.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Me thinks the E-Brake cable is installed wrong
[Re: Pyper70]
#1604954
04/08/14 10:11 PM
04/08/14 10:11 PM
RapidRobert
shine your drop light on it then retake the pic so it'll be clear. Likely someone rigged something to shorten a stretched cable so the ebrakes would function
[Re: stumpy]
#1604958
04/09/14 07:54 PM
04/09/14 07:54 PM
Pyper70
Athens, Greece
it goes over to the driver side and up to the e-Brake
[Re: stumpy]
#1604960
04/10/14 02:22 AM
04/10/14 02:22 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Is there a slot in the backside of the T mount/ trans X member.
I am truckless..
[Re: 340SHORTY]
#1604961
04/10/14 10:07 AM
04/10/14 10:07 AM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
Here is how it is sposed to be hooked up.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: Pyper70]
#1604962
04/10/14 10:46 AM
04/10/14 10:46 AM
Posts: 674 Kennewick, Wa.
71vert340
Kennewick, Wa.
I believe the J bolt is to be hooked into the hole to the right of the hole the fuel lines are passing through in your picture, not through that bottom hole. Terry
[Re: Challenger 1]
#1604965
04/10/14 01:27 PM
04/10/14 01:27 PM
MOPARMIKE69
Nashville, TN
Yours is missing the support hook that hooks to the transmission cross member.
[Re: MOPARMIKE69]
#1604966
04/10/14 01:53 PM
04/10/14 01:53 PM
Challenger 1
Cincinnati, Ohio
Good point. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Challenger 1]
#1604967
04/10/14 02:37 PM
04/10/14 02:37 PM
Pyper70
Athens, Greece
I figured some component was missing....there is no reason there should be four spacers on that tensioner.
I'll make my own extension and hook it on to the trans crossmember...I wish I could power wash that entire undercarriage and blow all that grease and debris away....but I dont want all the crud on my drieway
Thanks for the pictures and schematics.
