Pre magnunm 308 heads. What's the CC? #1603881
04/06/14 10:16 AM
04/06/14 10:16 AM
Elk Grove, Calif.
bigblock340power Offline OP
Elk Grove, Calif.
Does anyone know the CC (or have CC'd a set) of the production pre-magnum 308 heads? The heads that came on production 360 engines 1987-92 (I think those are the years, anyway the ones just before the Magnum engines came out).
Re: Pre magnunm 308 heads. What's the CC? [Re: bigblock340power] #1603882
04/06/14 11:43 AM
04/06/14 11:43 AM
As you know they are open chambered. I think I have the nominal CC number wrote down somewhere (assuming you're good with a nominal ballpark figure)
Re: Pre magnunm 308 heads. What's the CC? [Re: RapidRobert] #1603883
04/06/14 02:09 PM
04/06/14 02:09 PM
scratchnfotraction Offline
about the same as all open chamber 360 heads.
the exhaust port is what changed to make it the better flowing head.
they are also prone to cracking with low casting #s to be had.
Re: Pre magnunm 308 heads. What's the CC? [Re: RapidRobert] #1603884
04/06/14 03:29 PM
04/06/14 03:29 PM
Elk Grove, Calif.
Elk Grove, Calif.
Yes, that would be fine.
Re: Pre magnunm 308 heads. What's the CC? [Re: bigblock340power] #1603885
04/06/14 04:02 PM
04/06/14 04:02 PM
72 CC
