Re: I NEED HELP! Trying to use Stage VI heads with Blower
[Re: DAYCLONA]
#1603813
04/06/14 02:59 AM
04/06/14 02:59 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
do you have the standard 440 port heads or the MW port heads ??
I am truckless..
[Re: kryogenic]
#1603815
04/07/14 03:39 PM
04/07/14 03:39 PM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
My question is, I want to run my stage VI mopar performance heads and a blower. From my underdtanding there is no blower intake that will fit it properly. I have some spacer place, but do i need my blower intake modified to fit the stage VI heads, or is there a blower intake made for this setup?
What block and exacty which head ?
If this is on an RB block then you need the spacer and a 440 manifold .
If this is on a B block then you can run a 440 intake , no spacers required , if you have a 383/400 blower intake then you will need the spacers.
If these are the std port window location 311 heads then it's 440 intake on RB , 383/400 intake on a B block , no spacers for either would be needed.
Can't say what you would need to do if they are 6's with a max wedge port window.
