Re: NHRA inspection [Re: B G Racing] #1603442
04/05/14 05:35 PM
04/05/14 05:35 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
Is there pro's and con's to getting the car certified?
Re: NHRA inspection [Re: maxie] #1603443
04/05/14 05:39 PM
04/05/14 05:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah.... $150 out of your pocket if its not needed
Re: NHRA inspection [Re: maxie] #1603444
04/05/14 05:43 PM
04/05/14 05:43 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Pro's; it allows you to run the car for 3 yesrs with a NHRA licensed driver, aftermarket axles, certified harmonic balancer, trans shield ,heather tethers, and window net.
Cons: It's $150 you don't need to spend if you go 10.0 or slower. You also don't need to spend the $350-$400 to get a NHRA license (every 2 years) either.
Doug
Re: NHRA inspection [Re: dvw] #1603445
04/05/14 05:51 PM
04/05/14 05:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Doug
That and stepping up to another jacket, pants and
neck collar plus a full face helmet
Re: NHRA inspection [Re: maxie] #1603446
04/05/14 07:28 PM
04/05/14 07:28 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Yes. As I understand it, if they check the cage and it fails for any reason, the car will not be legal to run quicker than 11.50. An illegal bar is no bar as far as NHRA is concerned.
Beyond that, if you know it will be OK and want to spend the money to have it tagged, you will have that piece of mind and the car will have the tag should you ever decide to go faster or sell the car.
Re: NHRA inspection [Re: CMcAllister] #1603447
04/05/14 08:10 PM
04/05/14 08:10 PM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
If the cage fails:
Do they tag it as failed or mark it in any other way
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: NHRA inspection [Re: DragDart360] #1603448
04/05/14 09:17 PM
04/05/14 09:17 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
If the cage fails:
Thats a good point
Re: NHRA inspection [Re: dvw] #1603449
04/05/14 09:25 PM
04/05/14 09:25 PM
Speedway In.
I
IndyDave Offline
IndyDave  Offline
I
Speedway In.
Doug
I will never complain about my SCCA dues again.......
Dave Dusterberg
1979 Aspen R/T (soon to be #19 CAM/T)
2002 Ram 1500 SLT
2005 Magnum R/T
2005 Mustang GT SCCA CAM/C #19
Re: NHRA inspection [Re: DragDart360] #1603450
04/05/14 09:27 PM
04/05/14 09:27 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
If the cage fails:
They don't mark the cage, but they have a record of the owner and the car. You fill out the paperwork before they check the car. And if it fails, everyone standing around spectating will know it.
Re: NHRA inspection [Re: CMcAllister] #1603451
04/05/14 10:57 PM
04/05/14 10:57 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
You get the form back noting that it has failed. After fixing you need to carry that form back to the next cert tech.
I agree with the majority and recommend that you not cert the car unless you are going below 10.0. I had mine certed several years ago and after it expired I won't do it again until needed. I know it will cert and have that confidence that it is good.
Mine was failed because 2 bars were CM instead of MS. Don't know why the cage builder did that. It certed after replacing the 2 bars.
Re: NHRA inspection [Re: Blucuda413] #1603452
04/06/14 02:39 AM
04/06/14 02:39 AM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
Just to be clear, the car has a full cage with halo and front a-pillar bars? They are not evident in the photo and most mail order kits do not fit that perfect.
A roll bar is required at 11.49 and faster in the 1/4 mile. A roll cage is required at 9.99 and faster.
A car with a roll bar does not get a certification.
The chassis inspection is JUST for the roll cage, and is only a certification that the cage meets SFI specification. It is NOT a tech inspection for safety and class requirements.
A car with a roll cage that has swing-out side bars can be certified to run from 9.99 to 8.50.
Of course to drive the car at 9.99 (6.40 1/8 mile) or faster, the driver must have an NHRA license as well.
The advantage of having a certified roll cage in a car that runs slower than 10.00 would be mostly for re-sale, as the car could than be marketed as having a cage that is NHRA legal to run down to 8.50.
If you have additional questions, feel free to contact me (PM or phone (in profile) is fine) as I am an NHRA tech inspector.
Scott Spies
Re: NHRA inspection [Re: ProStDodge] #1603453
04/06/14 02:52 AM
04/06/14 02:52 AM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Run the car and see if you need the certification first
