NHRA inspection #1603422
04/05/14 03:02 PM
04/05/14 03:02 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
I have an appointment May 3 to get the demon inspected by the NHRA at muncie drag way. According to the guy I spoke with on the phone they are only going to check the cage. Isn't there anything else they will check?
Seat belts are up to date
Helmet is up to date
Has a driveshaft loop
has overflow bottle
has battery cut off switch
It is a street strip car with all functioning lights
Re: NHRA inspection [Re: maxie] #1603423
04/05/14 03:08 PM
04/05/14 03:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you getting it certed... they look at the chassis...
tech looks at all the rest
Re: NHRA inspection [Re: MR_P_BODY] #1603424
04/05/14 03:10 PM
04/05/14 03:10 PM
Guitar Jones Offline
This. ^^^
Re: NHRA inspection [Re: Guitar Jones] #1603425
04/05/14 03:43 PM
04/05/14 03:43 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
I just went to the muncie drag way website.
It says:
NHRA Chasis inspection date is May 3
The guy I spoke with on the phone said it takes around 15 minutes per car and is $150. That they check roll cage welds and tubing thickness
Said he sets up the appointments for the nhra to do the work at the track.
Re: NHRA inspection [Re: maxie] #1603426
04/05/14 03:45 PM
04/05/14 03:45 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
Hope to make the first pass on the car that day, it hasn't been down the track yet. We have put 40-50 miles on the car since completion.
Hope to put the split mono leafs on it tomorrow and take the xhd springs off it.
Re: NHRA inspection [Re: maxie] #1603427
04/05/14 03:46 PM
04/05/14 03:46 PM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
Sweet Ride, How fast is it
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: NHRA inspection [Re: DragDart360] #1603428
04/05/14 03:52 PM
04/05/14 03:52 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
It's not the road runner in the picture, it is a 72 dodge demon we built last year.
433 hemi
11 to 1 compression
600/600 248 at 50 solid roller
dick landy roller rockers
diamond pistons with 990 tool steel pins
manly I beam rods
a and a transmission cross ram with two 770 holleys
a and a 727 with a 3800 converter
dana 60 with 4.10's
all steel car weighing in at 3700 lbs
Re: NHRA inspection [Re: maxie] #1603429
04/05/14 03:53 PM
04/05/14 03:53 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
Re: NHRA inspection [Re: maxie] #1603430
04/05/14 03:57 PM
04/05/14 03:57 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Man, lower the rear of that thing........... Good luck.
Re: NHRA inspection [Re: Thumperdart] #1603431
04/05/14 04:09 PM
04/05/14 04:09 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
Hope to put the "0" stock ride height mono leafs on it tomorrow.
I can fit my fist between the top of the tire and the wheel lip
Re: NHRA inspection [Re: maxie] #1603432
04/05/14 04:16 PM
04/05/14 04:16 PM
Indy
moparman89 Offline
moparman89  Offline
Indy
That chassis inspector is a very knowledgeable and easy goin guy. Good luck!
School of Automotive Machinists Racing
Re: NHRA inspection [Re: maxie] #1603433
04/05/14 04:37 PM
04/05/14 04:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It says:
They are talking cert for $150... do you run less
than 10.0... and do you have a cage
Re: NHRA inspection [Re: MR_P_BODY] #1603434
04/05/14 04:41 PM
04/05/14 04:41 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
car has a cage and I have no clue as to what it will run.
My guess would be 11.00's
The cage is one of the jegs kits with the swing out bars.
Re: NHRA inspection [Re: maxie] #1603435
04/05/14 04:45 PM
04/05/14 04:45 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
433 hemi
11 to 1 compression
manly I beam rods
dana 60 with 4.10's
Cheese and rise is that car FAT (3700)
Don't you HEMI guys know how to build a light car.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: NHRA inspection [Re: maxie] #1603436
04/05/14 04:47 PM
04/05/14 04:47 PM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
Hey nice looking car , I will be there also to race . Hope to see your car in person . Gary
Re: NHRA inspection [Re: Gabby63] #1603437
04/05/14 05:04 PM
04/05/14 05:04 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
My appointment is at 9:00 AM
Re: NHRA inspection [Re: maxie] #1603438
04/05/14 05:06 PM
04/05/14 05:06 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
I have vintage 60's and early 70's decals I have been debating putting on it.
Erson
racer brown
DLI
kendall gt-1
and so on
Re: NHRA inspection [Re: pittsburghracer] #1603439
04/05/14 05:10 PM
04/05/14 05:10 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
433 hemi
11 to 1 compression
manly I beam rods
dana 60 with 4.10's
The weight is with me in it (185 lbs) and a full tank of fuel
so without me the car is 3515. changing to the mono leafs should take 40-50 pounds off of it.
The car is all steel with full interior. Heavy dana, roll cage, 4 wheel disc, frame tied, full 3 inch exhaust, normal gas tank, iron heads on the motor. The intake weighs 22 pounds
Re: NHRA inspection [Re: maxie] #1603440
04/05/14 05:20 PM
04/05/14 05:20 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If it runs 10.0 or slower there is no reason to spend the $150 to certify it. It's legal to run 10.0 if it passes tech.
Doug
Re: NHRA inspection [Re: dvw] #1603441
04/05/14 05:25 PM
04/05/14 05:25 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
If your not going to run faster than 10.00 do not certify the car.
