Re: NHRA inspection
[Re: MR_P_BODY]
#1603424
04/05/14 03:10 PM
04/05/14 03:10 PM
Posts: 20,698 in a cattle trailer down by th...
Guitar Jones
Are you getting it certed... they look at the chassis... tech looks at all the rest
This. ^^^
Re: NHRA inspection
[Re: maxie]
#1603427
04/05/14 03:46 PM
04/05/14 03:46 PM
Posts: 492 South Jersey, NJ
DragDart360
South Jersey, NJ
Sweet Ride, How fast is it
70 Dart Swinger, 2850 lbs SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: NHRA inspection
[Re: DragDart360]
#1603428
04/05/14 03:52 PM
04/05/14 03:52 PM
Posts: 7,065 Indiana
maxie
Indiana
It's not the road runner in the picture, it is a 72 dodge demon we built last year.
433 hemi 11 to 1 compression 600/600 248 at 50 solid roller dick landy roller rockers diamond pistons with 990 tool steel pins manly I beam rods a and a transmission cross ram with two 770 holleys a and a 727 with a 3800 converter dana 60 with 4.10's
all steel car weighing in at 3700 lbs
Re: NHRA inspection
[Re: maxie]
#1603430
04/05/14 03:57 PM
04/05/14 03:57 PM
Thumperdart
State of confusion
Man, lower the rear of that thing........... ![](/ubbthreads/images/graemlins/biggrin.gif) Good luck.
Re: NHRA inspection
[Re: Thumperdart]
#1603431
04/05/14 04:09 PM
04/05/14 04:09 PM
maxie
Indiana
Man, lower the rear of that thing........... Good luck.
Hope to put the "0" stock ride height mono leafs on it tomorrow.
I can fit my fist between the top of the tire and the wheel lip
Re: NHRA inspection
[Re: maxie]
#1603432
04/05/14 04:16 PM
04/05/14 04:16 PM
Posts: 171 Indy
moparman89
Indy
That chassis inspector is a very knowledgeable and easy goin guy. Good luck!
School of Automotive Machinists Racing
Re: NHRA inspection
[Re: maxie]
#1603433
04/05/14 04:37 PM
04/05/14 04:37 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I just went to the muncie drag way website.
It says:
NHRA Chasis inspection date is May 3
The guy I spoke with on the phone said it takes around 15 minutes per car and is $150. That they check roll cage welds and tubing thickness
Said he sets up the appointments for the nhra to do the work at the track.
They are talking cert for $150... do you run less than 10.0... and do you have a cage ![](/ubbthreads/images/graemlins/wave.gif)
Re: NHRA inspection
[Re: MR_P_BODY]
#1603434
04/05/14 04:41 PM
04/05/14 04:41 PM
maxie
Indiana
car has a cage and I have no clue as to what it will run. My guess would be 11.00's ![](/ubbthreads/images/graemlins/shruggy.gif) The cage is one of the jegs kits with the swing out bars.
Re: NHRA inspection
[Re: Gabby63]
#1603437
04/05/14 05:04 PM
04/05/14 05:04 PM
maxie
Indiana
Hey nice looking car , I will be there also to race . Hope to see your car in person . Gary
My appointment is at 9:00 AM
Re: NHRA inspection
[Re: pittsburghracer]
#1603439
04/05/14 05:10 PM
04/05/14 05:10 PM
maxie
Indiana
Cheese and rise is that car FAT (3700) Don't you HEMI guys know how to build a light car.
The weight is with me in it (185 lbs) and a full tank of fuel
so without me the car is 3515. changing to the mono leafs should take 40-50 pounds off of it.
The car is all steel with full interior. Heavy dana, roll cage, 4 wheel disc, frame tied, full 3 inch exhaust, normal gas tank, iron heads on the motor. The intake weighs 22 pounds ![](/ubbthreads/images/graemlins/shock.gif)
