Home-made exhaust? #1602858
04/03/14 09:08 PM
04/03/14 09:08 PM
Mt.Gilead, Ohio
OhioMopar Offline OP
Mt.Gilead, Ohio
Has anyone here walked into Jegs or Summit (insert other auto parts store here) and fabbed up an X-pipe exhaust for your B-body? I am just trying to figure out what X-pipe works and how long of an S-bend I need. My plan is to go to the rear axle and run turn downs from there.
Thanks.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Home-made exhaust? [Re: OhioMopar] #1602859
04/03/14 10:14 PM
04/03/14 10:14 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Magnaflo has real nice Xs and 2 into 1 componants. Go to their website and check them out.
I am truckless..
Re: Home-made exhaust? [Re: 340SHORTY] #1602860
04/03/14 10:22 PM
04/03/14 10:22 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
I'll check it out. Thanks.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Home-made exhaust? [Re: OhioMopar] #1602861
04/03/14 11:34 PM
04/03/14 11:34 PM
Nevada
dezduster Offline
dezduster  Offline
Nevada
I have cut a fishing spoon shaped piece off of two 45 degree bends and made my own x pipe, works well. I have also done this with the legs not flat so it actually curved down for angle also. Don't be hesitant to experiment. AN X AFTER THE MUFFLERS GIVES THE X SOUND AS WELL. But not the scavenging benefits.
Speedway motors exhaust kit.
Mild Steel Exhaust Bend Kit, 2-1/2 Inch
$139.99
Product Rating: 4.79 Stars
More Info
Re: Home-made exhaust? [Re: dezduster] #1602862
04/03/14 11:49 PM
04/03/14 11:49 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
I have done dozzens of exhaust that way personally I like the mandrel bends, and the slip fit. fit it, tac it, then weld it up if ya like it.
Re: Home-made exhaust? [Re: Moparnut426] #1602863
04/04/14 01:10 AM
04/04/14 01:10 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I use the Summit 3" X pipe kit. It's almost enough for a full exhaust (w/o tailpipes), all you may need to do is cut a bit, and add some straight pipes before the mufflers, then weld most of it. Then buy some turndowns. Mine was a bit more involved because I'm using Schumacher headers, and the collector is up and at an angle compared to regular headers.
Re: Home-made exhaust? [Re: Exit1965] #1602864
04/04/14 10:43 AM
04/04/14 10:43 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Very cool. I'm looking at 2.5" X-pipe and Pypes Violator mufflers. I think I'm going to start with the s-bends and the X, then the mufflers and turndowns.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Home-made exhaust? [Re: OhioMopar] #1602865
04/04/14 11:33 AM
04/04/14 11:33 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Just don't build an abortion like this and you'll be fine .
Re: Home-made exhaust? [Re: JohnRR] #1602866
04/04/14 01:13 PM
04/04/14 01:13 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
No worries there. It looks, um, interesting.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Home-made exhaust? [Re: dezduster] #1602867
04/04/14 01:33 PM
04/04/14 01:33 PM
$139.99
I've used their ex kits. heavy gauge/excellent slip fits on the swedged ends, well worth the money
Re: Home-made exhaust? [Re: RapidRobert] #1602868
04/04/14 01:38 PM
04/04/14 01:38 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Where are they out of?
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Home-made exhaust? [Re: OhioMopar] #1602869
04/04/14 01:48 PM
04/04/14 01:48 PM
www.speedwaymotors.com 1 mile from me. I used to work there
Re: Home-made exhaust? [Re: RapidRobert] #1602870
04/04/14 03:40 PM
04/04/14 03:40 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Very cool. Thank you...
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Home-made exhaust? [Re: OhioMopar] #1602871
04/04/14 06:03 PM
04/04/14 06:03 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
Here's mine:
Re: Home-made exhaust? [Re: dynorad] #1602872
04/04/14 06:04 PM
04/04/14 06:04 PM
dynorad Offline
dynorad  Offline
In the car:
Re: Home-made exhaust? [Re: dynorad] #1602873
04/04/14 11:22 PM
04/04/14 11:22 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
That looks good! Is that a kit or did you build it out of lengths of pipe?
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Home-made exhaust? [Re: JohnRR] #1602874
04/05/14 03:22 PM
04/05/14 03:22 PM
Nevada
dezduster Offline
dezduster  Offline
Nevada
JohnRR you have been beating on that piece a lot. While I agree with it probably not functioning as well as it should, someone may be very proud of that and you could be devastating that persons fragile sense of accomplishment and creativity.
AND no its not mine.
LOL If you keep posting that pic its going to be known as the JohnRR X pipe experiment.
OOOPS too late.
I typed in X pipe in the search and there it is that pic and your screen name next to it claiming you built it. OOHHH THE HUMILITY! JK Have a good weekend everybody.
Re: Home-made exhaust? [Re: dynorad] #1602875
04/05/14 03:33 PM
04/05/14 03:33 PM
Nevada
dezduster Offline
dezduster  Offline
Nevada
Dynorad have you ran that engine with any other exhaust? I am interested in the difference that might make in flow/sound/performance. Packaging wise that could assist many people.
Oh and I like the idea, makes it almost a oval tubing.
Re: Home-made exhaust? [Re: dezduster] #1602876
04/05/14 08:06 PM
04/05/14 08:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
OOOPS too late.
I'm still waiting on flow tests and drag strip testing showing how this design is better than the others ... since it's claimed the person who designed it is a highly acclaimed Exhaust designer/tester ???
I do feel bad though because the person that has it on there car is very proud of his car and I don't mean to be harping on that member. .
Re: Home-made exhaust? [Re: JohnRR] #1602877
04/07/14 04:49 PM
04/07/14 04:49 PM
dynorad Offline
dynorad  Offline
I have not run with a different exhaust. It sounds good with the Ultraflows, although I'm not sure I'd want to take a long trip with it. It has a howl that sounds very exotic.
I was searching for information about the optimum crossover area so I could fab my own x pipe and ran across the attached article.
Its not obvious in the picture, but the tubes run through the indents in the trans crossmember. The tubes are 3".
EDIT: I am running 2.5" tailpipes from TTI, not downturns.
