Re: Exhaust Manifold Studs
[Re: 340SHORTY]
#1602800
04/03/14 07:59 PM
04/03/14 07:59 PM
RapidRobert
What Shorty said & if you are talking about header bolts that are leaking I would highly suggest instead using the OE studs with the unthreaded shoulder in the middle & with headers you can shorten the outer fine threaded portion so that only enough remains to be flush with the nut after tightening. Any more than that is a waste & hampers header flange fitment
[Re: jkgtx70]
#1602803
04/04/14 09:57 AM
04/04/14 09:57 AM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
With studs the slight shoulder seals them.I use antisieze on them.I even use it on bolts when using headers.No leaks at all.That and when you go to remove them they will come right out.Rocky
Chrysler Firepower
