BRAKE LIGHT '86 d150 #1602541
04/03/14 02:51 AM
04/03/14 02:51 AM
Burkesville Ky.
gerty Offline OP
gerty  Offline OP
Burkesville Ky.
I had a rear brake line spring a leak. I replaced the lines and bleed the brakes. All is good except the brake light is still illuminated on the dash. Is there a way to reset the light?
Bob
Re: BRAKE LIGHT '86 d150 [Re: gerty] #1602542
04/03/14 08:04 AM
04/03/14 08:04 AM
Truckville, the capital of NY
85_Ram_4speed Offline
I wonder if the prop valve is stuck after loosing pressure on one side. As I recall there shouldn't be any real issues here, just a basic 'ole brake system. Maybe try tapping the valve?
Outcast Dodge guy.
Re: BRAKE LIGHT '86 d150 [Re: 85_Ram_4speed] #1602543
04/03/14 08:05 AM
04/03/14 08:05 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: BRAKE LIGHT '86 d150 [Re: 340SHORTY] #1602544
04/03/14 10:14 AM
04/03/14 10:14 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Try having someone in the truck.Then open a front bleeder and have them push the pedal down.Close then release the pedal.That usually resets the light and valve.Ive had to do it on some a few times to reset.Had to do a lot at work.Rocky
Chrysler Firepower
Re: BRAKE LIGHT '86 d150 [Re: gerty] #1602545
04/03/14 08:11 PM
04/03/14 08:11 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Make sure its not the parking brake making the light stay on.
Re: BRAKE LIGHT '86 d150 [Re: NITROUSN] #1602546
04/03/14 08:42 PM
04/03/14 08:42 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
A good, quick, and hard stomp of the brake pedal might be enough to reset the valve. Its worked for me in the past.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: BRAKE LIGHT '86 d150 [Re: NITROUSN] #1602547
04/03/14 09:43 PM
04/03/14 09:43 PM
east side of Ohio
basketcase Online content
basketcase  Online Content
east side of Ohio
1981 Dodge D150 360 auto
Re: BRAKE LIGHT '86 d150 [Re: basketcase] #1602548
04/04/14 02:59 AM
04/04/14 02:59 AM
Burkesville Ky.
gerty Offline OP
gerty  Offline OP
Burkesville Ky.
Thanks for all the suggestions Guys. Much appreciated!
Bob
