whats the trick? #1602430
04/02/14 10:59 PM
04/02/14 10:59 PM
Finally a HUSKER again
Moparnut426 Offline OP
its been a few years since I have replaced a steering gear on an ol MoPar. I know you shift the front to back to get the steering wheel to center, but My question is is there a trick? Ive moved it basically both directions front to back and got little to no change.
Kasey
Re: whats the trick? [Re: Moparnut426] #1602431
04/02/14 11:07 PM
04/02/14 11:07 PM
Andrewh Offline
Andrewh  Offline
you mean where the hoses come in for power steering right?
when you say no change, what do you mean? I have seen it rip the wheel all the way in one direction or another with small movements.
you do have the front end off the ground right?
Re: whats the trick? [Re: Andrewh] #1602432
04/02/14 11:15 PM
04/02/14 11:15 PM
yes its off the ground, its on my hoist.
Do you guys leave the bolts kinda loose and adjust while its running?
I know little movements are what I did last time, but I moved it severely this time and got basically nothing.
Re: whats the trick? [Re: Moparnut426] #1602433
04/02/14 11:37 PM
04/02/14 11:37 PM
Harrisburg Pa. 17112
moparmikethree Offline
I don't like messing with them. I took my boss for a ride in my 70 Challenger doing about 40-45 and that top plate shifted while driving. The steering. Wheel ripped out of my hand a did a 45 degree turn on a dime. I was shaking for the rest of the day
Re: whats the trick? [Re: moparmikethree] #1602434
04/02/14 11:38 PM
04/02/14 11:38 PM
Kinda have to on this one, Its a rebuilt gear, and its wackoooooo
Re: whats the trick? [Re: Moparnut426] #1602435
04/02/14 11:41 PM
04/02/14 11:41 PM
Keep your wrists out of the steering wheel
Re: whats the trick? [Re: moparmikethree] #1602436
04/02/14 11:44 PM
04/02/14 11:44 PM
so any word on a trick here??
Re: whats the trick? [Re: Moparnut426] #1602437
04/02/14 11:50 PM
04/02/14 11:50 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I used to do them with the wheels in the air,SLIGHTLY loosen the bolts, start the car, at idle speed lightly tap it back and forth til the steering wheel stays centered. Been a LONG time, but did a bunch back in the day when I spent a LOT of time on the alignment rack... it could cause a pull
Re: whats the trick? [Re: Dcuda69] #1602438
04/02/14 11:52 PM
04/02/14 11:52 PM
ok, so its ok to do it with bolts lightly loose
thanks
Re: whats the trick? [Re: Dcuda69] #1602439
04/02/14 11:53 PM
04/02/14 11:53 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you bled it by going all the way to one side and holding it then going the other way and holding it? When you say you want it to center are you talking about even movement one side to the other or some other movement? Normally when you replace a gearbox you don't need to mess with the valve.
Re: whats the trick? [Re: stumpy] #1602440
04/02/14 11:58 PM
04/02/14 11:58 PM
The owner of the car has a uncle who rebuilt it for him, has done a lot of them, so the valve has been off. And I did go side to side and bled the air outa it. If I rev the engine a touch it still favors the left side.
Re: whats the trick? [Re: Moparnut426] #1602441
04/03/14 11:47 AM
04/03/14 11:47 AM
Andrewh Offline
Andrewh  Offline
is it giving any power assist at all?
could be bad flow/pressure is why you don't see any change.
Re: whats the trick? [Re: Andrewh] #1602442
04/03/14 04:13 PM
04/03/14 04:13 PM
Yes theres assist, just forces it to the left, its harder to turn to the right. Whickif its not "centered" that makes sence
Re: whats the trick? [Re: Moparnut426] #1602443
04/03/14 05:24 PM
04/03/14 05:24 PM
Andrewh Offline
Andrewh  Offline
so you are trying to move it with the car running and you are moving it a bunch, but no change?
how much is it leaking?
Re: whats the trick? [Re: Andrewh] #1602444
04/03/14 10:58 PM
04/03/14 10:58 PM
well i got it figured out, got it set, but it has a terrible leak out of the top of the adjuster jam nut. Mike is gonna get me a new gear, and I also noticed the power steering pump also is leaking pretty badly, so thats going on also.
So thanks guys..
Kasey
