SBM Edelbrock Heads CNC Ported, Need advice and pics #1601916
04/01/14 10:50 PM
04/01/14 10:50 PM
N. Of Detroit, Mi
733404spdCuda Offline OP
N. Of Detroit, Mi
All,
I'm looking for photos of CNC ported small block Edelbrock RPM heads.
Any issues with breaking through exhaust and valve cover bolt holes? should they be epoxied?
Thanks in advanced
Re: Looking for photos of SBM Edelbrock Heads CNC Ported [Re: 733404spdCuda] #1601917
04/01/14 11:46 PM
04/01/14 11:46 PM
Az
Crizila Offline
Crizila  Offline
Az
All,
Thanks in advanced
These were done by Hughes.
Fastest 300
Re: Looking for photos of SBM Edelbrock Heads CNC Ported [Re: Crizila] #1601918
04/01/14 11:47 PM
04/01/14 11:47 PM
Az
Crizila Offline
Crizila  Offline
Az
more
Fastest 300
Re: Looking for photos of SBM Edelbrock Heads CNC Ported [Re: Crizila] #1601919
04/01/14 11:50 PM
04/01/14 11:50 PM
Az
Crizila Offline
Crizila  Offline
Az
intake
Fastest 300
Re: Looking for photos of SBM Edelbrock Heads CNC Ported [Re: Crizila] #1601920
04/01/14 11:50 PM
04/01/14 11:50 PM
Az
Crizila Offline
Crizila  Offline
Az
exhaust
Fastest 300
Re: Looking for photos of SBM Edelbrock Heads CNC Ported [Re: Crizila] #1601921
04/01/14 11:52 PM
04/01/14 11:52 PM
Az
Crizila Offline
Crizila  Offline
Az
last one
Fastest 300
Re: Looking for photos of SBM Edelbrock Heads CNC Ported [Re: Crizila] #1601922
04/02/14 09:07 PM
04/02/14 09:07 PM
N. Of Detroit, Mi
N. Of Detroit, Mi
what about the breaking through on the bolt holes? should I epoxy them?
Re: Looking for photos of SBM Edelbrock Heads CNC Ported [Re: 733404spdCuda] #1601923
04/02/14 10:21 PM
04/02/14 10:21 PM
Idaho
LaRoy Engines Offline
Idaho
Not neccessary.
Re: Looking for photos of SBM Edelbrock Heads CNC Ported [Re: 733404spdCuda] #1601924
04/02/14 10:54 PM
04/02/14 10:54 PM
Az
Crizila Offline
Crizila  Offline
Az
I would, plus sealing the threads on the bolts that broke through. The heads in the pics are SB magnums. I had the intake manifold bolt holes redrilled to accept an LA intake manifold that I want to use. When Hughes redrilled and tapped them, they broke through to the water jacket on 3 of the 4 end manifold bolts. I obviously had leaks on fire up when the coolant pressure came up. I was able to reach in to the water jackets and seal those 3 corner break throughs from the back side with JB weld. Leaks fixed.
Fastest 300
