"402" oil pan 1969 440 oil drain plug washer #160176
12/02/08 04:20 PM
12/02/08 04:20 PM
Nanuet, NY
johntpr Offline OP
johntpr  Offline OP
Nanuet, NY
I know Badalson sells the correct oil drain plug...but does anyone make the correct oil drain plug washer or something close? Frank doesn't sell. My original is shot.
69 Daytona 4 speed
Re: "402" oil pan 1969 440 oil drain plug washer [Re: johntpr] #160177
12/02/08 07:48 PM
12/02/08 07:48 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Re: "402" oil pan 1969 440 oil drain plug washer [Re: gtx6970] #160178
12/02/08 08:11 PM
12/02/08 08:11 PM
Nanuet, NY
johntpr Offline OP
johntpr  Offline OP
Nanuet, NY
Don't know Bill.....have to take apart when I change oil agian..I know it is not brass or nylon so maybe it is aluminum. Thanks Bill
69 Daytona 4 speed
Re: "402" oil pan 1969 440 oil drain plug washer [Re: johntpr] #160179
12/02/08 08:32 PM
12/02/08 08:32 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
I don't think they were made of aluminum. It is very thin and made from some other soft ferrous metal. I am sure I have some originals kicking around, I'll look when I get to the shop.
Re: "402" oil pan 1969 440 oil drain plug washer [Re: HPMike] #160180
12/02/08 09:24 PM
12/02/08 09:24 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
For grins, here's the original part number: 2268 513 (which BTW was the same part number on ALL engine oil drain bolts on ALL 1969 engines).
