Powder coating blocks and heads, waterpump housings, intakes, etc have been done for years by the hotrodders,.....the resto crowd is slow to catch up,......I had a sixpack intake and smblk timing chain cover, after polishing them out, powder coated in clear years ago, just the heat crossover area darkened, but never lifted,......theres a lot of new masking techniques they use nowadays, I'd recommend just the outside of the block, heads, and whatever else you have done, see if they will mask off the machined, as well as internal areas.....plus I hope your aware they will sandblast the pcs to promote a serile surface, so cover surfaces that aren't meant to be blasted, and clean the piss out of it when it gets home, you don't want any traped sand, if no core plugs are in it, sand loves to build up in the cooling cores!.....be careful
