Torsion Bars for an E Body #1601042
03/31/14 05:14 AM
03/31/14 05:14 AM
NY
K
Killerinc Offline OP
K
NY
Hi,
I have a small block 74 E body that i want to swap over to a big block.
Is there a conversion motor mount kit of do i have to change the K Frame?
Also what diameter torsion bars should i go with for the street. I want a stiff/firm car in the corners. What is the stock BB diam. btw
Re: Torsion Bars for an E Body [Re: Killerinc] #1601043
03/31/14 06:26 AM
03/31/14 06:26 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
E body K frame is the same sm or Bblk, you just need the Bblk motor mounts for an E body
I'd change the bars to 1" minimum
Re: Torsion Bars for an E Body [Re: DAYCLONA] #1601044
03/31/14 04:54 PM
03/31/14 04:54 PM
NY
K
K
NY
Cool thx,
As for the torsion bars, some people are just giving me the last 3 numbers which doesn't help figuring out the diam.
someone on CL is selling BB HD Mopar Performance charger ones but he said i think they are .960 or .980
Re: Torsion Bars for an E Body [Re: Killerinc] #1601045
03/31/14 07:55 PM
03/31/14 07:55 PM
All I can add is I ran large (over 1") tbars & ss springs on a SB 65 dart (came with the ss and the tbars were what I had on hand at the time) & it rode nice & very very solid but the SS springs were too harsh & would have been changed eventually if I had not sold it
Re: Torsion Bars for an E Body [Re: RapidRobert] #1601046
03/31/14 11:48 PM
03/31/14 11:48 PM
IN
ahy Offline
ahy  Offline
IN
From memory, stock TB's with a BB were .94". The .96 or .98 would be a bit stiffer. I run 1" bars on mine (aluminum head BB) and they work great. With the 1" bars you should step up from stock replacement type shocks to control the higher rate.
Re: Torsion Bars for an E Body [Re: ahy] #1601047
04/04/14 03:22 AM
04/04/14 03:22 AM
NY
K
K
NY
What are the TB's you run part number wise?
are they exactly 1"
Re: Torsion Bars for an E Body [Re: RapidRobert] #1601048
04/04/14 03:30 AM
04/04/14 03:30 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Bars of same diameter but different lengths have different stiffnesses. A 1" A-body bar is going to be stiffer than a 1" E-body bar because it's shorter.
Re: Torsion Bars for an E Body [Re: MuuMuu101] #1601049
04/04/14 07:51 AM
04/04/14 07:51 AM
BDW Offline
BDW  Offline
Re: Torsion Bars for an E Body [Re: BDW] #1601050
04/04/14 10:00 AM
04/04/14 10:00 AM
Georgia
Steve Bryant Offline
Georgia
Just finished swapping a 318 for a 440 on my 70 Cuda and we went with the PST 1.03 for $219 shipped to my door. I listed the older small bars on Craigslist and ended up selling them pretty quickly. So far I am impressed with the PST bars but they are keyed a bit differently and perfectly match the lowered spindles I bought from PST. I don't think their 1.03 bars have much (or any) pre-load from what I can tell.
Re: Torsion Bars for an E Body [Re: MuuMuu101] #1601051
04/04/14 01:14 PM
04/04/14 01:14 PM
That would make sense that you'd have less leverage on a shorter bar & actually alot more of the rough ride than I attributed may have been from the Tbars. I got to thinking & blaming it on the SS springs (003 on both sides) since they raised the height up substantially (needed shock extensions) but it was a solid little A body
Re: Torsion Bars for an E Body [Re: RapidRobert] #1601052
04/04/14 06:14 PM
04/04/14 06:14 PM
NY
K
K
NY
Great thanks for the info, but sorry what is PST?
Re: Torsion Bars for an E Body [Re: BDW] #1601053
04/04/14 06:50 PM
04/04/14 06:50 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
That list ought to be, of not already, in the Tech/Archives section, assuming its accurate.
Re: Torsion Bars for an E Body [Re: Killerinc] #1601054
04/04/14 07:00 PM
04/04/14 07:00 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
http://www.p-s-t.com/
