Car stalls on hard braking #1600917
03/30/14 11:53 PM
03/30/14 11:53 PM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
Hey guys,
I'm getting the car ready for the drive to Van Nuys for the Spring Fling and while the car runs great, it has developed a nagging issue.
It wants to stall on hard braking. The carburetor is a Grant VS 850. The sight plugs on the side show the fuel level to be right in the middle when sitting and idling. I thought it could have been a fuel pressure problem, so I changed the Holley for a Carter pump. I still have to two foot it on a quick stop. I plan to install some better front brake pads tomorrow which I guess will only worsen the stalling.
It idles at 1100 and at 800-850 in gear. I can sit idling in gear and it has no tendency to stall. I have a vacuum pump to power the brakes. The timing is set to 20 initial and 34 total. The car runs absolutely great except for this.
What can cause this other than the float level ?
Re: Car stalls on hard braking [Re: Kern Dog] #1600918
03/31/14 12:01 AM
03/31/14 12:01 AM
IN
ahy Offline
ahy  Offline
IN
Did this start with the vacuum pump install? They typically have check valves so the pump won't "suck" from the carb/manifold. As a diagnostic, you could cap and plug all connections from the carb or manifold to the vacuum system and give it a try.
Re: Car stalls on hard braking [Re: ahy] #1600919
03/31/14 12:58 AM
03/31/14 12:58 AM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
Try a hose on the float bowl vent tubes. It could be gushing a little bit of fuel splash out of them and into the throat of the carb when you brake hard.
Re: Car stalls on hard braking [Re: Kern Dog] #1600920
03/31/14 01:24 AM
03/31/14 01:24 AM
Is the level supposed to be in the middle of the sight glass(es). I ain't a Holley guy but I had always thought that with them at the bottom was correct where you had to slightly rock the eng to get a slight bit of spillage. You might take out the idle mix screws & shoot a 2 second blast of starting fluid into each hole then replace the screws (count the # of turns so you can quickly replace em exactly where they were). Holler how it goes
Re: Car stalls on hard braking [Re: RapidRobert] #1600921
03/31/14 01:29 AM
03/31/14 01:29 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
That's what i thought at the bottom of the plug or just barely dribbling out at idle on level ground. That's what i have read on Holleys since day one!
Re: Car stalls on hard braking [Re: ademon] #1600922
03/31/14 01:35 AM
03/31/14 01:35 AM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
Yes, the fuel should just dribble out the sides at idle. As said that is how I was taught and set my Holley carbs up.
Re: Car stalls on hard braking [Re: SCATPK] #1600923
03/31/14 02:04 AM
03/31/14 02:04 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I had a '67 Barracuda that would stall at stops. The thrust bearing was the culprit, it wore out & the crankshaft was sliding forward in the block causing the engine to stall when the counterweights hit the block webbing.
If you find metal shavings in your oil pan, take it apart.
Re: Car stalls on hard braking [Re: Kern Dog] #1600924
03/31/14 02:14 AM
03/31/14 02:14 AM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
Floats too high, bottom of glass!
Re: Car stalls on hard braking [Re: loaderpro] #1600925
03/31/14 03:21 AM
03/31/14 03:21 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Floats too high....I wouldn't have thought that was a possible problem. I'll get back at it tomorrow.
Re: Car stalls on hard braking [Re: Kern Dog] #1600926
03/31/14 03:30 AM
03/31/14 03:30 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
BG says to put the fuel level in the middle of the sight plug as I recall, Holley says the bottom.
I'd suspect the vacuum pump. With the engine idling pump the brake pedal repeatedly over and over and see if the idle will change or if the car will stall.
Re: Car stalls on hard braking [Re: GTX MATT] #1600927
03/31/14 04:30 AM
03/31/14 04:30 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
I wonder if the vacuum pump is related. The lines only go to the brake booster, not to the engine in any way.
The info I have here that came with the carb does show that the fuel should be at the center of the sight glass.
Re: Car stalls on hard braking [Re: Kern Dog] #1600928
03/31/14 11:25 AM
03/31/14 11:25 AM
You might lower the fuel level termporarily for a check just to see if fuel sloshing is the culprit or if it is something else. Then you can easily return the floats to where they are now. The more I think about it the more I think it definitely is carb related
Re: Car stalls on hard braking [Re: RapidRobert] #1600929
03/31/14 04:17 PM
03/31/14 04:17 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree with this as I have seen high float level cause stalling like that alot.
Also as "67Satty" said it wont hurt to put a small rubber type hose across the bowl vents so fuel cant slosh out the bowl vent into the carb. Many racers do this so fuel dont sloch out when they yank the front end up. Ron
Re: Car stalls on hard braking [Re: 383man] #1600930
03/31/14 05:16 PM
03/31/14 05:16 PM
ontario canada kingston
aspenrt360 Offline
aspenrt360  Offline
yep sounds a lot like float level to me
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: Car stalls on hard braking [Re: aspenrt360] #1600931
03/31/14 05:22 PM
03/31/14 05:22 PM
P
Paul_Fancsali Offline
P
Set mine exactly on edge sight glass edge never stalls and never runs out on top. Have to rock the car to get gas out of it, done this for close to 20 years By the way if using the plastic floats be sure there is a surge spring on them if not you will get the same problem your having
Re: Car stalls on hard braking [Re: 383man] #1600932
03/31/14 08:33 PM
03/31/14 08:33 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
I will try lowering the float level.
Regarding the carb vents, do you mean to put a vacuum line connecting the primary and secondary vents?
I just put in a new Auto Meter liquid filled fuel pressure guage. The Mr gasket guage had an erratic needle. It has 11 lbs of pressure. I ran the car yesterday and had no fuel overflow problems but I wonder how far I am pushing my luck. I've never used a regulator and am not sure how to plumb one, where to place the components, etc.
Re: Car stalls on hard braking [Re: Kern Dog] #1600933
03/31/14 09:23 PM
03/31/14 09:23 PM
I do believe we have found the problem
Re: Car stalls on hard braking [Re: Kern Dog] #1600934
03/31/14 09:23 PM
03/31/14 09:23 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Yeah, 11psi is too much, Holley recommends 7 psi max, not sure what your carb manufacturer recommends though.. Your vent still need to be vented, what you are doing is putting a hose over both of the metal tube vents in a sort of arc, then at the peak of the arc you will cut a notch in the hose to allow it to vent and also raise the opening up.
http://www.rockcrawler.com/techreports/holley_truck_avenger/index.asp
They use a metal tube, but you get the idea.
Don't be the exception.
Re: Car stalls on hard braking [Re: RapidRobert] #1600935
03/31/14 10:49 PM
03/31/14 10:49 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
It was doing the same thing with the Holley pump that maxed out at 7 lbs.
I am tempted to put in a regulator with a return line to the tank. I seem to remember that some guys use the 1/4" vent line as their return line, right?
It is either plumb in a regulator or put the Holley pump back in for the trip.
Re: Car stalls on hard braking [Re: Kern Dog] #1600936
03/31/14 11:36 PM
03/31/14 11:36 PM
Even at 7 psi showing (actual may even be higher) that might be too much. Gonna be interesting to see how it acts when you reg it down. We gotta get this
