Going back to all Glass
#1599461
03/28/14 01:02 AM
03/28/14 01:02 AM
Posts: 449 Hampton,Va
QuickDart 502
Hampton,Va
Has anyone weighed all they're glass.
Re: Going back to all Glass
[Re: 80fbody]
#1599464
03/28/14 09:23 AM
03/28/14 09:23 AM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
When we went to lexan and fiberglass doors on our 69 Dart small tire car I weighed the stock glass: Doors complete with glass & regulators were 68.5lbs. ea. Quarter glass & regulators 9lbs. ea. Rear glass 17lbs. We kept the glass windshield so I don't have a weight for it.
Mike Gray
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: Cab_Burge]
#1599465
03/28/14 12:08 PM
03/28/14 12:08 PM
QuickDart 502
Hampton,Va
My eyeglasses weigh a lot less than the windsheild in my car I haven't weighed either though What year and body style are you wondering about
Apparently you don't need to weigh your glasses you need to have them checked I attached a picture of the car. Oh wait! Click on the word ATTACHMENT incase the all black color of the car effects your eye sight ill tell ya. It's a 1969 Dodge Dart
[Re: Plumb Wired]
#1599466
03/28/14 12:11 PM
03/28/14 12:11 PM
QuickDart 502
Hampton,Va
Mike Gray
Thanks Mike, I decided to go back to all glass from lexan because the car is going to be street driven quite a bit plus its less a pain to clean it.
[Re: Airwoofer]
#1599468
03/28/14 04:07 PM
03/28/14 04:07 PM
QuickDart 502
Hampton,Va
I just got a set of the guts that make the glass go up and down. When I picked up the box I was kinda shocked at how much it weighed. Not the glass itself, just the guts that make it work.
Also on my car the door X bar is right where the handle is so I have to open the door to crank down the window. This is on a Demon.
That Dart will be quite intimidating rolling around the street! Atre you gonna leave the parachute on?
And the wheelie bars
[Re: QuickDart 502]
#1599469
03/28/14 04:15 PM
03/28/14 04:15 PM
Posts: 43,248 Bend,OR USA
Cab_Burge
That is a race car If I don't express myself well on here then I know, especially, on here, someone will say so Your windows weigh different than mine do, how much remains to be determined BTW, the reason for my attachment is to show you, and anynone else intereted, in seeing the differences in the size of the variuos Mopar window sizes from the A bodies to the E bodies
[Re: Cab_Burge]
#1599471
03/28/14 06:01 PM
03/28/14 06:01 PM
QuickDart 502
Hampton,Va
Thanks Cab.
[Re: MR_P_BODY]
#1599472
03/28/14 06:04 PM
03/28/14 06:04 PM
QuickDart 502
Hampton,Va
Is it the factory original glass... factory glass IS heavier than a replacement glass(factory was thicker)
Its replacement glass thats good to know. But the rear glass does have the pentastar on the glass.
[Re: ProSport]
#1599474
03/28/14 07:39 PM
03/28/14 07:39 PM
QuickDart 502
Hampton,Va
I don't care if glass weighed 500 pounds more I'll never run lexan again, well maybe that's an exaggeration.
Your car will have so much power it's not gonna care about a few extra pounds. And it looks amazing by the way.
Thanks Bob
[Re: QuickDart 502]
#1599475
03/28/14 08:19 PM
03/28/14 08:19 PM
Posts: 9,863 MI, usa
dvw
MI, usa
Yes, my windshield is stock, 31 lbs. By removing the door,vent,rear 1/4 and back glass and replacing it with 1/8" Lexan I saved 84 lbs on my 64 Belvedere. You can make it look nice, just takes a little effort. This vent is Lexan (Vents are 1/4") Doug
[Re: dvw]
#1599477
03/28/14 09:48 PM
03/28/14 09:48 PM
QuickDart 502
Hampton,Va
Thanks Douglas
[Re: n20mstr]
#1599478
03/28/14 09:51 PM
03/28/14 09:51 PM
QuickDart 502
Hampton,Va
Mike Gray
We are talking A body here correct.... My windshield (oem) was 23 lbs (1973 dart) so this and the above weights should give you a good idea of a total weight for all windows
Thanks Tony, that gives me a general idea. With all the glass it should still come in under 3000 lbs.
[Re: QuickDart 502]
#1599480
03/29/14 12:54 PM
03/29/14 12:54 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
do you care if it is half full or half empty
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
