Page 3 of 3 1 2 3
Re: ? For those that run Drag Radials (rear) on the street [Re: mshred] #1599365
03/28/14 09:59 PM
03/28/14 09:59 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
The radials in the link below are the ones I am talking about...I think street driving on the cheapy tires is more dangerous then racing them, thats just my opinion though
http://www.mandhtires.com/M-H-Front-Runner#.UzXYfvldVgk
My post above has a direct link to the 26" radial front runners that are on my Charger. The work just fine and are ok in a light rain if you are respectful and have the brake proportion set up correctly.
Re: ? For those that run Drag Radials (rear) on the street [Re: Jeremiah] #1599366
03/28/14 10:07 PM
03/28/14 10:07 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Didn't even notice that sorry lol...Yea apparently they are a pretty good tire. I would rather run those then the cheapies, a little more peace of mind I feel like
Re: ? For those that run Drag Radials (rear) on the street [Re: mshred] #1599367
03/28/14 10:15 PM
03/28/14 10:15 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I had some cheap Les Schwab tires on the front and they felt funny at higher speeds no matter what the air pressure was. Also that was after I rebuild the front end, etc. I currently have the M&H's on a 3.5" rim but have been keeping an eye out for a set of 4" Prostars for the front.
Re: ? For those that run Drag Radials (rear) on the street [Re: Jeremiah] #1599368
03/28/14 10:56 PM
03/28/14 10:56 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I use a 205/75/15 on a 4" wheel.Works great.The tires are Firestone from Tires Plus.
Nautilus Racing-
Re: ? For those that run Drag Radials (rear) on the street [Re: Chris2581] #1599369
03/28/14 11:28 PM
03/28/14 11:28 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Check out the Vredestein Sprint from Coker. They have a 165/15, basically an old sports car/VW tire with a vintage appearance. Kind of looks a Sportsman front but it's a radial. I think they have a decent speed rating. About $115 each, not a bad price. A cheaper alternative to a Michelin XZX.
http://www.cokertire.com/165hr15-vredestein-sprint-blackwall-tire.html
'71 Duster
'17 Ram 1500
Re: ? For those that run Drag Radials (rear) on the street [Re: Jeremiah] #1599370
03/28/14 11:56 PM
03/28/14 11:56 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
proportion set
I have been looking at those.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: ? For those that run Drag Radials (rear) on the street [Re: 1967dartgt] #1599371
03/29/14 12:12 AM
03/29/14 12:12 AM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I am running Lemans 165 R15 and would like to go to a slightly taller MT Sportsman Front tire. Does anybody know which one I should buy.
THANKS....
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: ? For those that run Drag Radials (rear) on the street [Re: MR_P_BODY] #1599372
03/29/14 12:22 AM
03/29/14 12:22 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Im running the Nexens also,
165s IIRC
Re: ? For those that run Drag Radials (rear) on the street [Re: D-50] #1599373
03/29/14 12:25 AM
03/29/14 12:25 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
THANKS....
The 165 tire is 25.5 tall and a sportsman is available in 26.
Re: ? For those that run Drag Radials (rear) on the street [Re: 1967dartgt] #1599374
03/29/14 12:34 AM
03/29/14 12:34 AM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Thanks 1967DartGT, I have been having a problem Red lighting and thought going to a taller tire might help.
Re: ? For those that run Drag Radials (rear) on the street [Re: bigdad] #1599375
03/29/14 07:22 AM
03/29/14 07:22 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
I put a Mickey Thompson tire on the front of mine. It's not the SR, but I can't remember the name. No street miles to say how they do. I did learn that I shouldn't have put them on, seeing how the rears won't be hooking with the Street radials on the back and a stick.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Page 3 of 3 1 2 3
