Help me select a cam #1598811
03/26/14 06:40 PM
03/26/14 06:40 PM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
Need some help for selecting a new cam for my 70 Charger.
Here is what I have:
440 with 915 heads = higher than stock compression
3.23 SG rear end (won't change since I do some long distance trips)
intake: Holley Street Dominator or Edelbrock Performer RPM
carb: Quickfuel 750 vacuum secondary or 850 Thermoquad
cheap headers
current cam: Mopar .509
A-833 4-speed (2.66 first) tranny
Should I go for an off the shelf cam or a custom cam? Any recommendations?
Re: Help me select a cam [Re: DGS] #1598812
03/26/14 07:59 PM
03/26/14 07:59 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
call a cam company and get their reccomendation. Thats where you will get the best info you will ever get.
I am truckless..
Re: Help me select a cam [Re: 340SHORTY] #1598813
03/26/14 08:53 PM
03/26/14 08:53 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
lunati voodoo 60303. I ran it in a smogger 440 and it was a little soft in the bottom end. but with your compression and the stick shift it would be right at home
Re: Help me select a cam [Re: DGS] #1598814
03/26/14 09:17 PM
03/26/14 09:17 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Can you be specific?
Re: Help me select a cam [Re: DGS] #1598815
03/26/14 10:01 PM
03/26/14 10:01 PM
Central NC
gch Online content
gch  Online Content
Central NC
cheap headers
Max performance I would sar rpm intake and quickfuel 750
Max mileage I would say Thermoquad but w/o street dominator.
Street dominator is an excellent intake but I would rather have a dual plane in a heavy car with 3.23 gears.The standard performer would work but would sacrifice some mid range/top end.
Are you going to run the stamped stock rocker arms or aftermarket roller/adjustable??
We do need to know your actual compression and whether any work has been done to the heads for a specific recommendation.
Off the shelf stuff I would say somewhere in the high 220's/low 230's on the intake duration at .050.
Re: Help me select a cam [Re: gch] #1598816
03/26/14 10:33 PM
03/26/14 10:33 PM
IN
ahy Offline
ahy  Offline
IN
Does it need to be hydraulic? If solid is an option, the MP 528 cam is a good one. It should be more streetable and not give up much if any HP. Otherwise, a fast ramp shelf grind from Hughes or Comp in the 230'ish range (intake duration @.050) should work well. Note I'm assuming since you put some miles on you may want a bit less overlap vs the 509.
On Hydraulic vs solid... the solid has the edge in power and drivability and I think its easier to set up compared to a hi po hydraulic. Either really needs adjustable rockers. The solid will make some "sewing machine" valvetrain noise but so will a fast ramp hydraulic.
Re: Help me select a cam [Re: DGS] #1598817
03/27/14 04:04 AM
03/27/14 04:04 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The Performer RPM is fairly tall and may make air filter to hood clearance a problem unless your car has a scoop?
I like the Voodoo cams, they use the 3-bolt timing gear. The Comp XE cams are also good if you need to use the single bolt timing gear.
Are you looking for a cam milder than the Mopar 0.509?
knowing the actual compression ratio would help. Do you know what pistons are used and the cc's of the heads?
Re: Help me select a cam [Re: DGS] #1598818
03/27/14 09:14 AM
03/27/14 09:14 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Six pack, MP 528 solid w/ 1.5 roller rockers lash tight. It will run great. If you want a hydro cam, call and have a custom grind made or go with the Eddy RPM cam 7177 (488/510)
The six pack will give you better performance and economy than either of those carbs. If you want to stay 4bbl, I'd go with an old fashion 750DP or 750HP. (although for max HP you'll need a bigger carb)
Coming soon!!!!
Re: Help me select a cam [Re: Mr.Yuck] #1598819
03/29/14 05:11 PM
03/29/14 05:11 PM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
Thanks guys. Unfortunately I don't know the exact compression ratio - engine was rebuilt in the past but previous owner didn't what was done to the engine.
Not stuck on a hydraulic grind but I would like some more vacuum than with the 509.
I have a set of BB max wedge adjustable rocker arms on the shelf - not a true 1.5 more like 1.45 I've been told. Would these work or should I get a different set of rocker arms?
Re: Help me select a cam [Re: DGS] #1598820
06/25/14 04:47 AM
06/25/14 04:47 AM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
I was recommended the Comp Cams XS274S. It has an intake duration of 236 @.050 which should work well.
Before I pull the trigger on this cam is there anything from Hughes which would work?
Re: Help me select a cam [Re: DGS] #1598821
06/27/14 07:19 PM
06/27/14 07:19 PM
Washington, IL
Hughes Offline
Hughes  Offline
Washington, IL
Shoot me an e-mail at kevin@hughesengines.com with the answers to as many of these questions as possible and I will help you pick one out.
Engine size (cubic inch displacement)
Weight of vehicle, with driver (if a driver is used)
What category does your use fit? 1 thu 8 See below.
Altitude where vehicle will be run.
Desired ET or MPH
Present camshaft (duration @ .050", Lobe separation angle, lift etc...)
Final gear ratio
Stall speed of torque converter
Tire height and width
Fuel type
Static or Mechanical compression ratio
Iron or aluminum heads
Measured Compression Ratio
Intake manifold
Header type and size
Carburetor size
Rocker arm type and ratio
Will power adders be used? (N.O.S., turbo, supercharger etc...)
Cylinder head air flow numbers
Re: Help me select a cam [Re: DGS] #1598822
06/27/14 07:55 PM
06/27/14 07:55 PM
IN
ahy Offline
ahy  Offline
IN
On the rockers, I think those (iron adjustables I assume) would work fine if in good shape. The iron rockers need a shaft with correct hardness. If you are not sure about yours, new shafts recommended by the cam supplier would be good insurance. The shafts Comp supplies with their cast steel rockers would be fine also.
Re: Help me select a cam [Re: Hughes] #1598823
06/27/14 08:36 PM
06/27/14 08:36 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Do yourself a favor and call a couple cam companies, including Hughes. See who asks all the important information to make a wise choice. As you can see by Kevin's post, Hughes will.
The only company I trust enough to pick something if I didn't spec my own would be Hughes.
Keith
Re: Help me select a cam [Re: Dunnuck Racing] #1598824
06/27/14 10:27 PM
06/27/14 10:27 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
IIRc a member Dwayne Porter will also grind you a custom cam.I believe Ron 383 Man used his cam.He will make you one that works.Rocky
Chrysler Firepower
Re: Help me select a cam [Re: therocks] #1598825
06/30/14 08:47 AM
06/30/14 08:47 AM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
Thanks guys, I will shoot an e-mail to Kevin an Dwayne.
Re: Help me select a cam [Re: DGS] #1598826
06/30/14 12:14 PM
06/30/14 12:14 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I second Dwayne. He has been spot on in cam choices when I have used him
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Help me select a cam [Re: B3422W5] #1598827
06/30/14 12:22 PM
06/30/14 12:22 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
If the engine runs now take a cranking psi reading ... that will give a good idea to the cam company on which way to go. And what the engine will be happy with.
Re: Help me select a cam [Re: DGS] #1598828
06/30/14 02:56 PM
06/30/14 02:56 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
What are your goals in the NEW cam as compared to what you have right now?
Sounds like you are looking to stick with something right for the gear ratio you have (if I'm reading the posts correctly). I second the 230@0.050 recommendation...beyond that you may want to play with the LSA and so forth to smooth out the idle and drive for more vacum at lower RPM.
Re: Help me select a cam [Re: Diplomat360] #1598829
06/30/14 06:07 PM
06/30/14 06:07 PM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
You're right I want to stick with the 3.23. Goals are nice torque curve with enough vacuum for power brakes.
