Failing Trans Memory #1598356
03/25/14 05:07 PM
03/25/14 05:07 PM
North Carolina
Mikeymopar68 Offline OP
North Carolina
I am about to put my freshly rebuilt 1977 360 back in my Warlock and I am going to freshen up the transmission housing with some nice durable aluminum paint (yes I know they were not factory painted) but I need to know what color, if any, the transmission drain pain was painted? If they were I cannot remember...... HELP!
Re: Failing Trans Memory [Re: Mikeymopar68] #1598357
03/25/14 06:20 PM
03/25/14 06:20 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
They weren't painted. Use "cast aluminum" paint on the trans for a more stock look.
Re: Failing Trans Memory [Re: stumpy] #1598358
03/25/14 06:25 PM
03/25/14 06:25 PM
dogdays Offline
dogdays  Offline
There was a lot of stuff under the car that was never painted. Think they'd waste paint on something that no one would ever see?
R.
Re: Failing Trans Memory [Re: dogdays] #1598359
03/25/14 09:17 PM
03/25/14 09:17 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I like the rebuilders cast paint I prefer the cast gray but that is just a personal preference
http://www.plastikote.com/products/Specialty/Rebuilders-Cast-Finish.html
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Failing Trans Memory [Re: stumpy] #1598360
03/26/14 10:38 AM
03/26/14 10:38 AM
North Carolina
North Carolina
Thanks for the idea. I was also thinking of gun metal grey also.
Re: Failing Trans Memory [Re: dogdays] #1598361
03/26/14 10:40 AM
03/26/14 10:40 AM
North Carolina
North Carolina
Well if Mother Mopar would not "waste" paint on things people would not see then why did they paint the engine oil pan and the frame bottoms and other underneath items!
Re: Failing Trans Memory [Re: Mikeymopar68] #1598362
03/26/14 02:38 PM
03/26/14 02:38 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Oil pan was painted when the rest engine was. Frame was dipped for rust prevention. Trans didn't need painting because it was aluminum so why spend the time or money painting the pan separately.
Re: Failing Trans Memory [Re: stumpy] #1598363
03/27/14 12:19 PM
03/27/14 12:19 PM
North Carolina
North Carolina
If you were in the process of completely restoring your 37 year old truck and the engine is going to be like "NEW", would you bolt up an old gungy looking transmission to it? True, originally the trans was not painted but after 37 years of road grime, grease, fluids and use it will never look new again without a decent coating of a good durable paint. It has been completely rebuilt internally so the outside deserves to look just as good. I no not what you would choose to do if it was yours but for me a few extra dollars to make my old Dodge truck look good is worth it no matter how it was done 37 years ago!
Re: Failing Trans Memory [Re: Mikeymopar68] #1598364
03/27/14 01:44 PM
03/27/14 01:44 PM
dogdays Offline
dogdays  Offline
Lighten up. Nobody said don't paint it. Your question was what was it painted originally, the answer was "nothing".
I paint everything that I put back together because I like the neat appearance. But I am not restoring to "factory new appearance" either.
So if I want to paint the block black, I go ahead and do it. If the valve or cam covers get painted aluminum color, it's because I think it contrasts the black nicely.
And if my newer truck engine is a bright gold color, it's because there were three spray cans in that color in the Clearance section at Walmart!
R.
Re: Failing Trans Memory [Re: Mikeymopar68] #1598365
03/27/14 02:24 PM
03/27/14 02:24 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I answered this question. Unbunch your tighty whities.
Re: Failing Trans Memory [Re: dusturbd340W5] #1598366
03/27/14 06:19 PM
03/27/14 06:19 PM
Guitar Jones Offline
I paint my transmissions and engines black. But that's just me.
Re: Failing Trans Memory [Re: Guitar Jones] #1598367
03/28/14 03:51 PM
03/28/14 03:51 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Once you've had to clean a few hundred unpainted cases you'll realize the value of painting them. Paint seals the pores of the casting so crud won't stick to them as tenaciously.
