Glass polishing
#1598242
03/25/14 11:20 AM
03/25/14 11:20 AM
Posts: 3,712 Sacramento, Ca
Darius
Sacramento, Ca
Has anyone used the Eastwood glass polishing product? i have some hazing on the inside of my 70 GTX rear window and nothing I have tried will cut it, including 4 ott steel wool and even clay bar. Is the eastwood product worth it? If not, any suggestions will be appreciated
Driving modern convenience in classic beauty
Re: Glass polishing
[Re: Darius]
#1598243
03/25/14 11:33 AM
03/25/14 11:33 AM
Posts: 1,574 Lakeland FL
floridian
Lakeland FL
If you used 0000 steel wool on it and that did nothing I can't imagine anything else working.. The steel wool probably made it worse.. Is the WS in or out of the car??
Re: Glass polishing
[Re: Darius]
#1598247
03/25/14 12:36 PM
03/25/14 12:36 PM
floridian
Lakeland FL
Glass is IN the car
Then you will not be able to use the Eastwood system.. You would ruin your interior...
I want to think that backglass is tempered, so not sure what the "haze" would be.. A Windshield would have the laminate in it so it could haze with age..
