Re: best mechanical fan for big block
[Re: 4406bbl]
#1597221
04/09/14 07:55 AM
04/09/14 07:55 AM
Posts: 1,491 Lethbridge, AB, Canada
dangina
Always use a standard duty fan clutch and never a heavy duty on an engine with mods that will allow higher revs. Standard clutch fans slip about 20 percent more and a heavy duty can get you into a fan rpm safety issue. Hayden has a great website that explains it all. Hayden also sells fan blades that fit the clutch, cheap.
cool! how do you tell the difference between the standard and the heavy duty clutch?
