1957 dodge truck frame transplant? #1596432
03/22/14 01:23 AM
03/22/14 01:23 AM
North Central Florida
E
eightlitermopar Offline OP
E
My dad has a very slow project ongoing:
1957 Dodge D100
The frame is solid, but we have run into a problem.
We have a 440 and automatic transmission in place, but I cannot see how we can make the steering work. The motor is right in the way and there is no way around it unless we completely redneck it. We have not touched the cab and we would prefer not to cut it up if possible.
Here is my first question: The frame is original with front leaf springs etc…..
Would I be better off at this point with a new frame to put the cab on? This way the 440 and the steering would work?
Here is the follow up question: If a new frame swap would be easier….what trucks would work the best?
I know of a 1982 dodge truck, long bed, 2wd.
Or….should I go with the Dakota frame instead?
We are at a crossroads where we could go many directions at this point.
Eightlitermopar
Attached are the pictures of the truck as it sits right now....
Mopar or no car
Re: 1957 dodge truck frame transplant? [Re: eightlitermopar] #1596433
03/22/14 01:24 AM
03/22/14 01:24 AM
E
E
another view
Mopar or no car
Re: 1957 dodge truck frame transplant? [Re: eightlitermopar] #1596434
03/22/14 01:58 AM
03/22/14 01:58 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
A 2 wheel drive Dakota front clip will work a lot better then a full size Dodge truck frame would. You will want to splice the Dakota frame to your existing frame just behind the transmission cross member, where the Dakota frame will slide right inside your existing frame. The Dakota frame steps up 6" behind the cab, your original frame is nearly flat behind the cab, swapping the whole Dakota frame will create issues for your box and its floor. The 88-90 Dakota has a 5 on 4 1/2" bolt pattern. The 91-96 Dakota has the 6 bolt wheels, but they are easily changed by swapping the rotors to the older 5 lug rotors. The 97- 20 something used a different frame with 6 lug wheels, changing to the 5 lug wheels is a major project. The frame after the 97- 20something frame was a different style frame and a suspension change, which will make it a completely different project. Gene
Re: 1957 dodge truck frame transplant? [Re: poorboy] #1596435
03/22/14 09:20 AM
03/22/14 09:20 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
A few u-joints and a support to run the shaft next to the shock tower.
Re: 1957 dodge truck frame transplant? [Re: eightlitermopar] #1596436
03/22/14 10:36 AM
03/22/14 10:36 AM
UP
finn Offline
finn  Offline
UP
I'd suggest that you look into some of the engineered kits that use Mustang II based components. They are the most popular and, all things considered, not all that expensive. People do use the Dakota parts, but that's not as popular. The entire frame can be swapped, but that has issues of its own with cab mounts,etc.
Re: 1957 dodge truck frame transplant? [Re: finn] #1596437
03/22/14 12:12 PM
03/22/14 12:12 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
mustang II are only barely adequate----mustang guys upgrade to granada components---hot rod guys know that their big block setups have too much power for the MII brakes---early dakota clip is the way to go.....
Re: 1957 dodge truck frame transplant? [Re: savoy64] #1596438
03/22/14 12:23 PM
03/22/14 12:23 PM
E
E
Hmmm....good thoughts here.
I could try the u-joint trick and see if that could work. That seems like it would be the least invasive....for now anyway.
Since I have never set up steering like this....does anyone have a site or resource they recommend for something like that (u-joints for steering)?
I am also keeping my eyes peeled for a cheap early Dakota if this plan does not work.
eightlitermopar
Mopar or no car
Re: 1957 dodge truck frame transplant? [Re: eightlitermopar] #1596439
03/22/14 09:07 PM
03/22/14 09:07 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Flaming river, Morrison chassis, ART, They all have steering components.
Re: 1957 dodge truck frame transplant? [Re: savoy64] #1596440
03/23/14 12:47 AM
03/23/14 12:47 AM
UP
finn Offline
finn  Offline
UP
I'm not sure where you are getting your information from.. The MII kits all seem to use an 11' rotor, which is pretty close to the 11.3 of the Dakota. The Granada spindles and brakes are a popular swap into 50's Fords using the original suspension, but nobody in their right mind would use a Granada suspension, which is like the early (pre-MustangII) with the unibody shock tower high spring mount. It would never work.
The advantage of the MII is that these kits have been out there for probably 25 years now and there are many reputable companies offering well thought out kits. They don't require butchering your frame and jerry rigging a front core support like a clip does
The MII kits are proven and popular.
Another swap that is becoming very popular is the Jaguar suspension. It is a bolt on unit on the late Jag and is supposedly pretty available and reasonable.
The Crown Vic (03 up) is another unit that is popular on the 50's Ford ickups, but seems to be a little wide, so you have to use the Crown Vic wheels.
People do use the Dakota clip, but it doesn't seem popular.
Clipping was a 70's and 80's thing. Latest builds seem to avoid it.
Re: 1957 dodge truck frame transplant? [Re: finn] #1596441
03/23/14 01:59 AM
03/23/14 01:59 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Dakota is a Really Great option. Gives you indapendant suspension and Rack and pinion. I may be interested in his current axle setup
Re: 1957 dodge truck frame transplant? [Re: 76dodgeboy] #1596442
03/31/14 07:04 AM
03/31/14 07:04 AM
E
E
Thanks again guys...I think we are going to figure out steering first before we start transplanting.... I honestly didn't know how easy or complicated it would be.
I will let you know how it turns out!
Mopar or no car
Re: 1957 dodge truck frame transplant? [Re: eightlitermopar] #1596443
04/03/14 12:26 AM
04/03/14 12:26 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
The late model Crown Vic seems like a good solution. Good brakes, steering and suspension in a self contained cradle that takes 4 bolts to secure. I think I read on the Sweptline forum that the width on the cradle is 34" and the Dodge frame is slightly narrower.
Kevin
Re: 1957 dodge truck frame transplant? [Re: Twostick] #1596444
06/26/14 08:12 PM
06/26/14 08:12 PM
Ontario, Canada
K
KBD Offline
KBD  Offline
K
Ontario, Canada
It sounds like an interesting project you and your Dad are working on. I am working on a similar project, a 57 that my Dad gave me a lot time ago. I hope you find the following helpful.
I’m going the same route as you a 440, go big or go home. Now if I had to do it all over again I would consider a stroked 360/340 with a turbo.
To free up some room on the driver’s side, I made the centre line of the drive train ¾” off centre towards the passenger side. This helps with the headers and the steering, but I still had to do some mods to the frame…..cutting and re-enforcing. I’ve install a mustang II with coil overs, however moving the motor over might give you enough room to slide the steering rod pass the manifolds. It will also free up some room on the firewall if you put a brake booster on it. Attached are some pictures of the steering linkage.
Goodluck!
8188524-MopartI.pdf (328 downloads)
