1970 truck hood turn signal #1596262
03/21/14 05:40 PM
03/21/14 05:40 PM
Illinois, USA
superbee69 Offline OP
Illinois, USA
need to see if someone has measurements for where the holes are in the hood for turn indicator & where the wires go
Re: 1970 truck hood turn signal [Re: superbee69] #1596263
03/24/14 09:28 PM
03/24/14 09:28 PM
Maine
V
VanishingPt 2009 Offline
V
Maine
Here are some measurements I took from a 70 D100 Adventurer in a junkyard....I removed the turn signals to install them on my truck, so I took some pictures =so that I could accurately drill my hood
It is 29 1/8 from the center line of the hood to the center of the signal holes
and it is 36 3/4 to the center of the bulb hole from the back edge of the hood
hope this helps !!
Re: 1970 truck hood turn signal [Re: VanishingPt 2009] #1596264
03/24/14 09:35 PM
03/24/14 09:35 PM
Maine
V
V
Maine
the truck I removed the signals from
Re: 1970 truck hood turn signal [Re: VanishingPt 2009] #1596265
03/25/14 02:10 PM
03/25/14 02:10 PM
Illinois, USA
Illinois, USA
thanks so much thats what i needed for placement of lamps know just need to know where wires go so it does not look haked.
