Re: welding ???????????? chromoly to mild steel
[Re: all spooled up]
#1596246
03/21/14 06:09 PM
03/21/14 06:09 PM
Posts: 52,972 Romeo MI
MR_P_BODY
can u weld a chromoly part to a mild steel part with a tig welder
Yes any time you join moly to mild you have to play it just like moly... in other words it has to be tigged
[Re: sg66mopar]
#1596248
03/21/14 07:10 PM
03/21/14 07:10 PM
MR_P_BODY
Are we talkin' cage here or just mild to Moly in general?
I've mig welded the two a few times over the years in "non critical" applications with no problems.
Just did the 7.50 upgrade on the Charger the last couple weeks and tig welded the Moly to the old mild steel cage. Proud owner of an NHRA 7.50 sticker.
If its a chassis the first joint to mild( if adding moly HAS to be tigged .. then each joint has to be tigged if its moly.... IF by chance you are adding mild to moly(chassis or cage set up)the first joint where the moly and mild connect it has to be tigged then all the rest of the mild can be migged... if its not a cert thing, then yes you can mig it.. but I dont like to.... I tend to tig even mild for a nicer looking weld
#1596250
03/21/14 07:22 PM
03/21/14 07:22 PM
Posts: 1,288 Oregon
sg66mopar
I'd definitely tig that. ER70S2 rod, in my opinion.
[Re: sg66mopar]
#1596251
03/21/14 07:31 PM
03/21/14 07:31 PM
Posts: 1,049 ohio
all spooled up
ohio
thanks
[Re: MR_P_BODY]
#1596253
03/22/14 01:33 AM
03/22/14 01:33 AM
Posts: 1,049 ohio
all spooled up
ohio
