Dodge ram V 10 Crankshaft question #1596127
03/21/14 12:42 PM
03/21/14 12:42 PM
Wichita Kansas
6PacCuda Offline OP
6PacCuda  Offline OP
Wichita Kansas
Will the pistons go up far enough in the block to get the crankshaft out without having to tear the motor down. A family friend has one with 50K on it and it might have a crank problem. I think it has a rod knock.
Re: Dodge ram V 10 Crankshaft question [Re: 6PacCuda] #1596128
03/21/14 02:06 PM
03/21/14 02:06 PM
Vallejo, CA
ditchdrift Offline
ditchdrift  Offline
Vallejo, CA
if it has rod knock, the rod that has the spun bearing will have to be changed. you will also have to pull the transmission to get the crank out and raise the engine. Might as well pull the motor out and go through it the right way instead of jerry rigging it.
Re: Dodge ram V 10 Crankshaft question [Re: 6PacCuda] #1596129
03/21/14 02:07 PM
03/21/14 02:07 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I changed a crank in a 350 like that once ... make sure all the valve are closed before attempting .
Re: Dodge ram V 10 Crankshaft question [Re: JohnRR] #1596130
03/21/14 03:59 PM
03/21/14 03:59 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Maybe but I don't think so.Last crank pin is out of sync.Do it right and besides the rods will need reconditioning (with new bolts) if one spun.
Leave the gun.......take the Cannoli's....Mike
Re: Dodge ram V 10 Crankshaft question [Re: mike s] #1596131
03/21/14 06:32 PM
03/21/14 06:32 PM
Wichita Kansas
6PacCuda Offline OP
6PacCuda  Offline OP
Wichita Kansas
There are no spun rod bearings. It has a little rod knock on start up and its a farm truck that they do not want to throw tons of money at. They thought that if you could put a crank kit in it for a few hundred they would.
Re: Dodge ram V 10 Crankshaft question [Re: 6PacCuda] #1596132
03/21/14 08:52 PM
03/21/14 08:52 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
If it's a farm truck and only knocks on start-up I wouldn't mess with it. In case of failure those engines are cheap cuz' nobody wants 'em.
Re: Dodge ram V 10 Crankshaft question [Re: redraptor] #1596133
03/21/14 09:13 PM
03/21/14 09:13 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
only on startup could be piston slap or lifter not pumped up,
Re: Dodge ram V 10 Crankshaft question [Re: d-150] #1596134
03/21/14 11:34 PM
03/21/14 11:34 PM
IN
ahy Offline
ahy  Offline
IN
Sometimes rolling in a new set of bearings will take care of that type of problem. You should be able to do that with pan off. More than that, I'd pull the engine.
