1997 2500 5.9 magnum 4x4 dies when put into gear
#1595604
03/20/14 12:08 AM
03/20/14 12:08 AM
Posts: 51 Jacksonville, AR
dmckeehan
Jacksonville, AR
Had the toy out last weekend playing. Made a run in 4low through the mud, turned around to make a second pass. put the truck into reverse from a full stop and as soon as truck went into reverse it jerked and stalled. started right back up, put it into reverse again, same thing, jerk then stalled. Put it into drive, same thing. pulled it to the house. No noise at anytime during this that was out of ordinary. Today, put transfer case into neutral and transmission shifts through all gears fine. put transfer case in gear, stalls. pulled drive shafts, and left transfer case in gear, truck does fine. jacked up both axles and they turn free. Any suggestions?
1985 Crew Cab W250 4x4 - daily driver, 5.9 magnum, carbed and distributor, A-518 and NP205 2002 3500 extended cab, 4x4, Cummins and 6 speed 1997 Ram 2500 5.9 with 35 Boggers - Mud Racer 1993 Dakota 4x4, Dana 60's front and rear - work in progress 1992 Dakota 2wd short bed, awaiting 440 swap
Re: 1997 2500 5.9 magnum 4x4 dies when put into gear
[Re: dmckeehan]
#1595605
03/20/14 01:07 AM
03/20/14 01:07 AM
Posts: 905 SD
zrxkawboy
SD
Check Engine light on? My first thought was IAC, but could be a lot of things.
Off the top of my head: TPS: maybe it got wet during the mud run? Check fuel pressure. Throttle body clean?
It's Swifty! Swifty, you toad sucker!
[Re: zrxkawboy]
#1595606
03/20/14 08:11 AM
03/20/14 08:11 AM
dmckeehan
Jacksonville, AR
No check engine light. it is almost like the engine stalls because of load
[Re: DusterDave]
#1595608
03/20/14 03:28 PM
03/20/14 03:28 PM
Posts: 21,084 Niles , Ohio
therocks
Niles , Ohio
Check the battery and cables.A weak battery will do crazy things to the computer.Rocky
Chrysler Firepower
[Re: therocks]
#1595609
03/20/14 03:41 PM
03/20/14 03:41 PM
Posts: 4,255 Canada
WO23Coronet
Canada
My brother had an 82 Cordoba that did the same thing, forward gears were fine, but stick it in reverse and it would die, unless you feathered the throttle, popped it into reverse and could get it going, the it would back up, but U still couldn't stop or it would die. Its like u described, it would load the engine immediatey then die. The tranny was pooched, not sure what but we changed it out and it was fine. Since u were mudding, I would go with a tranny problem
[Re: WO23Coronet]
#1595610
03/20/14 04:52 PM
03/20/14 04:52 PM
Posts: 20,667 in a cattle trailer down by th...
Guitar Jones
The converter clutch is applying, most likely the converter is bad but there could be other issues in the trans that may have caused it.
[Re: ChrgrCuda]
#1595612
03/20/14 09:13 PM
03/20/14 09:13 PM
Posts: 1,090 st.cloud fl
d-150
Smarter than a 5th grader?
st.cloud fl
[Re: d-150]
#1595613
03/21/14 11:00 AM
03/21/14 11:00 AM
dmckeehan
Jacksonville, AR
thanks guys! looks like a wrenching weekend before the first race!
[Re: dmckeehan]
#1595614
03/28/14 05:00 PM
03/28/14 05:00 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
Had a 91 Dakota that did the same thing. It would run fine until you came to a stop and then just shudder and die. No trouble lights. It would start but wouldn't run in gear.
Went on for a few months intermittently, always ran fine when I took it to the dealer. Turned out to be something like a speed sensor. Apparently the computer didn't realize the truck had stopped and needed to change to idling from coasting or some such.
Before you tear it apart, try doing a neutral drop and see if it will run fine like mine did once it starts rolling. Not something to make a habit of with any automatic, but might direct you to a sensor instead of an unneeded transmission R&R that won't fix the problem.
Cheers.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
