Jaz Fuel Cell leaking issues?? #1595464
03/19/14 05:30 PM
03/19/14 05:30 PM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
So, I've taken the cell apart several times, replaced the white gaskets and tightened it to what I feel is tight. I'm afraid if I go too tight I will crack the gasket. But no matter what I've tried it still has a very, very slow leak. Has anyone else had this issue? Do you have any ideas for a fix that will work, short of buying an aluminum cell with welded bungs, that's my last resort...
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Jaz Fuel Cell leaking issues?? [Re: DemonDust] #1595465
03/19/14 07:17 PM
03/19/14 07:17 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I'll assume the outlet is leaking. Get some better nylon washers. I put some thicker washers on my cell, cranked down the fitting & all is well.
Re: Jaz Fuel Cell leaking issues?? [Re: DemonDust] #1595466
03/19/14 08:22 PM
03/19/14 08:22 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I've never had that problem with the 2 Jaz cells I have used.
It sounds like something is worn?
I would recommend a good pipe dope. Dope will seal fuel. Good luck.
Re: Jaz Fuel Cell leaking issues?? [Re: rickraw] #1595467
03/19/14 10:34 PM
03/19/14 10:34 PM
Menomonee Falls
Menomonee Falls
Yes one of my feeds in my sump is leaking. I bought Jaz washers, is there a better one out there? Maybe I'm not cranking it down tight enough.
SDG Motorsports
Re: Jaz Fuel Cell leaking issues?? [Re: Challenger 1] #1595468
03/19/14 10:36 PM
03/19/14 10:36 PM
Menomonee Falls
Menomonee Falls
I'll try cranking it down one more time like Rick suggested,if that still doesn't work I'll try the pipe dope.
Thanks for the suggestions
SDG Motorsports
