1967 gtx stripes #1594748
03/18/14 11:34 AM
03/18/14 11:34 AM
O
otter440 Offline OP
otter440  Offline OP
O
can anyone tell me the measurements for the hood and trunklid stripes on a 67 gtx that I need to paint on? Also are the stripes gloss or semi they are going black Thanks
Re: 1967 gtx stripes [Re: otter440] #1594749
03/19/14 07:59 PM
03/19/14 07:59 PM
O
otter440 Offline OP
otter440  Offline OP
O
would also need the sixe of the stripe. HELP HELP
Re: 1967 gtx stripes [Re: otter440] #1594750
03/21/14 12:21 PM
03/21/14 12:21 PM
IN
GTX4spd Offline
GTX4spd  Offline
IN
Try Dave Patik of Car Graphix. He's the restoration advisor for the Winged Warriors/ National B-Body Owners Assoc. & if he doesn't have the info he can probably point you in the direction of someone who does.
His email is CarGraphix@aol.com, phone # is 850-878-1450
"Gentlemen, we must all hang together, or surely, we shall all hang seperately."--Benjamin Franklin www.wwnboa.org if you're interested in '62-'74 B-Bodies
Re: 1967 gtx stripes [Re: GTX4spd] #1594751
03/21/14 12:48 PM
03/21/14 12:48 PM
PA
RoadRunner73 Offline
PA
to Dave
1973 Plymouth Road Runner
Re: 1967 gtx stripes [Re: RoadRunner73] #1594752
03/21/14 04:48 PM
03/21/14 04:48 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
The fronts are centered over the high beams, width is 4". I measured my original stripes as 37-1/4 between the fronts. The rears are centered over the backup lights.
Re: 1967 gtx stripes [Re: otter440] #1594753
03/21/14 04:59 PM
03/21/14 04:59 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
4" wide gloss colors only, painted on. They are centered on the hood scoops, they go down below the grille on the filler panel also. Rears are not parallel to the fronts, they are centered over the backup light and go to the window trim, they are not parallel to the edge of the tunk lid. No pinstripes on either side of them either. These were an option, not standard equipment, about 25% of the cars came with them.
Re: 1967 gtx stripes [Re: NANKET] #1594754
03/21/14 05:33 PM
03/21/14 05:33 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
If the hood stripes are parallel & the trunk stripes are parallel then they are parallel to each other.
If they do not share the same center to center dimension that would be a different issue: alignment - "not in-line".
Re: 1967 gtx stripes [Re: NANKET] #1594755
03/21/14 05:36 PM
03/21/14 05:36 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
"Sport Stripes" were a $30.65 OPTION on a '67 GTX
Re: 1967 gtx stripes [Re: 6bblgt] #1594756
03/21/14 07:21 PM
03/21/14 07:21 PM
KY
b5a12bee Offline
b5a12bee  Offline
KY
I recently sold a original paint survivor GTX and the stripes on the front stopped at the hood and did not go below the grill
Re: 1967 gtx stripes [Re: b5a12bee] #1594757
03/21/14 07:29 PM
03/21/14 07:29 PM
KY
b5a12bee Offline
b5a12bee  Offline
KY
1 more
