11 inch brake problems!!! #1594734
03/18/14 09:38 AM
03/18/14 09:38 AM
west australia
8trackbee Offline OP
west australia
need some advice on a problem with the super bee's brakes A12 car,power brakes, 11 in drums, all rebuilt, new wheel cylinders, new master and booster, skimmed drums,new lines. brakes were working fine for about 6 months driving, they now have developed a problem with the brake pedal sticking to the floor a little bit... the brakes are not locking up but they do grab and pull you to a stop brake return spring is fine,i've adjusted them up but still same problem seems to be getting worse each day now, what should i look at first, i'm thinking master,or wheel cylinders
Re: 11 inch brake problems!!! [Re: 8trackbee] #1594735
03/18/14 01:09 PM
03/18/14 01:09 PM
On The Boat, On The Lake, Wa. ...
amxautox Online content
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Online Content
sticking master cylinder, or booster, or some link in that area
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: 11 inch brake problems!!! [Re: 8trackbee] #1594736
03/18/14 01:50 PM
03/18/14 01:50 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Since this is a handling oriented forum I would suggest the problem is that they are drums, might be time for discs.
Relevant advice, pull each drum and inspect the insides. I suspect an issue there.
Don't be the exception.
Re: 11 inch brake problems!!! [Re: 8trackbee] #1594737
03/18/14 02:57 PM
03/18/14 02:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Bad poppet valve in the booster...repair/replace.
